civic makes noise and stalls. NO check engine lights
I have a 2006 Honda Civic 5-Speed. I was on the highway yesterday and my car started making a rattling noise when I would push the gas pedal. Further down the road it got worse to where it would make the noise with out pushing the gas pedal. After the noise got worse it stalled for no reason. I was able to start the car but now the noise is even worse and the car stalled with out moving it. I restarted the car and I was able to keep it running as long as I held the gas pedal but the noise is ridiculous. I was able to limp the car to a safe place but am puzzled. No check engine light (can I still get a diagnostic done?), everything in the car and the dash are normal and not out of place. Any suggestions? Please help.
Re: civic makes noise and stalls. NO check engine lights
Didn't you open the hood?
Is the oil empty?
Is the coolant empty?
Did the drive belt come off, get shredded, pulleys fell apart, tensioner pivot bolt broke off? Water pump pulley broke off?
Sounds like you need a tow truck at any rate.
Is the oil empty?
Xuhme
21
Aug 7, 2023 03:40 PM
dooner24
Apr 14, 2015 07:51 PM
deus-ex
Apr 13, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
