Does the exhaust pipe sound normal?
Old Sep 28, 2013
Tiboi's Avatar
Tiboi is an unknown quantity at this point
Hi
2 weeks ago, I had an engine replacement done on my Civic 2009.
Since then, the sound coming out of the exhaust pipe sounds abnormal. I dont hear anything from the inside of the car.
I confirmed with a friend of mine and he thinks also there's something wrong. I am going back to show it to the dealer Monday.
Here is a video :
If you know what it is, let me know.
Thanks
Old Sep 28, 2013
Re: Does the exhaust pipe sound normal?
Originally Posted by Tiboi
Hi
Why? What happened to it?
Um, just how often did you ever sit behind your tailpipe and listen to the soothing sounds of your exhaust.....BEFORE the engine got replaced?
If it doesn't sound out of the ordinary from inside the car and sounds normal from the front of the car, then it's probably not an issue.
Since you don't hear anything in front, then it probably doesn't have any leaks in the front joints.
These are what would normally be taken apart to drop the drivetrain out the bottom, the rest of the exhaust from about the footwell area on back wouldn't be disturbed.
If that video was taken with a cold engine, it will sound different than if the engine is fully warmed up. They can sputter and slobber at times.
I think you might be trying to assign problems to something that is normal, looking for problems that aren't there. Or just now noticing something that has been there all along. (This is not at all unusual in my world!)
I think it's probably just fine, myself.
Compare it to another identical car first......under the same circumstances.
JMHO, YMMV
Old Sep 28, 2013
Tiboi's Avatar
I bought this civic (35000miles) a month ago. It used to belong to a 64 years old man. The car is really clean!!! I could hear somewhat a weird tapping noise at a cold start coming for the engine. It was hard to believe it is from the engine, specially at that low mileage.
It seems like the timing chain cover was leaking oil previously. The previous owner did not realize it and probably drove the car with low oil level for a while. Winter is pretty harsh over here in Canada. Engine cylinder no 1 and 3 got damaged. Engine got replaced under warranty.
Before the engine got replaced, I did inspect the car a few times cause I wanted to know if there were other issues. I dont remember the sound coming out from the tallpipe was that loud. But yeah, I should compare with another civic. The problem is that unluckily nobody through my family and friends have a civic. That would be weird to ask stranger "Can I listen to your pipe?"
Thanks for your comment.
Old Sep 28, 2013
Oh ok, you're THAT guy. I remember the thread now.
Gotcha.
That little plate with 3 bolts was a common leaker, but it was normally a very slow leak. Most just made some mess down the timing cover over a long period of time, instead of a rapid leak. Simple re-seal would have fixed it if someone had caught it in time.
And be known as "THAT guy"
Old Sep 28, 2013
Tiboi's Avatar
Thanks for the info. Other than this slow leak, I have no idea what could have cause the engine to break.
Anyway, anything else works fine.
[/QUOTE]
Yeah, you read my mind. LOL The dealer really wishes that I could be deaf.
Old Sep 28, 2013
Other than low oil level and/or lack of oil changes, there hasn't been much of any common problems that I have seen here (but then I am in a rather small dealer).
Unless it has a manual trans. "Lugging" the engine (very low RPM plus high load) can damage pistons, mostly due to insufficient splash lube at very low RPM.
One or two NCR*/NPF** freakouts are usually ok as long as you aren't wasting a lot of their time because of it and accept their answers.
But do it too much and you might earn a label........
You know you are special when you get labeled CSC***.
*No Charge Recheck
**No Problem Found
***Crack Smoking Customer
/slashie
Old Sep 28, 2013
Used to have a customer that was a music teacher.
She described every noise or rattle in terms of a tone, like "That rattle is an F#"
Old Sep 29, 2013
Tiboi's Avatar
LOL Did she ask you to tune her car?
Old Sep 29, 2013
Funny you say that....I keep a small harmonica in one of my toolboxes for the sole purpose of getting some of us techs harmonizing in key whenever one is asked to do a tune up.
It's great when done in front of new employees and customers that "get it".
Old Sep 29, 2013
Tiboi's Avatar
LOL!
You do more than your job, you entertain people! It must be a great laugh for people.
EK_Eddy
Jun 6, 2015 07:31 PM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
Mokushi
Dec 3, 2001 08:11 PM
Aznnp77
Nov 28, 2001 09:17 PM
colombianDXcivic
Nov 22, 2001 03:17 PM
