Honda civic 2013: HELP NEEDED!!!! Please and thank you!
Recently my key-less entry car keys was stolen. I'm going to reprogram the key at Honda dealership, this way the person who stole my key will not be able to access the car by remote, but he still have entry by using the key itself on the keyhole on the driver side. Any one have any suggestions to how to cover the key hole on the driver side or at least make it seem like its cover or plugged in someway? Changing the locks is out of budget range.
Re: Honda civic 2013: HELP NEEDED!!!! Please and thank you!
See if your insurance company will buy a set of locks.
Or buy just a door lock cylinder, it will come with new keys to fit it.
Coupe and sedan both use the same part#, you can buy the single outside door lock with new keys.
Part# 72185-TR0-A01, USD $35 from Majestic. ($50 retail)
Item #27 here (no pic, too new, 2012 is similar): http://www.hondaautomotiveparts.com/...-+OUTER+HANDLE
You can remove and reinstall the lock assembly from the door handle in 2 minutes. Single bolt holds it in.
I'm not sure what it takes to swap the key cylinder set out of the cover, because I have not had to do it yet.
HTH
jessicakaybby
Apr 20, 2015 12:11 PM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
