07 Si won't start please help!!!
Old Jan 18, 2014
00ACE00's Avatar
00ACE00 is an unknown quantity at this point
So this is my brothers car and i drove it for a day, Stalled in first gear and now it won't start.I changed his ECU to another one but didn't solve the problem ???
The only way to get it to start is by pushing it ?
Video below
View My Video
Old Jan 18, 2014
Re: 07 Si won't start please help!!!
Put the CORRECT PCM (ECU) back in it.
As long as that green key is flashing (immobilizer is in theft mode) you will never get it to run. (unless it's been modified and is supposed to flash like that)
Old Jan 18, 2014
00ACE00's Avatar
So put back the original ECU back in ?
Old Jan 18, 2014
00ACE00's Avatar
what if its doing the immobilizer is in theft mode with the original ECU, what do i do
Old Jan 18, 2014
Install the ECM that the key is married with.
(Key has an RFID chip that must match what the ECM is looking for.)
Where did your replacement ECM come from anyway?
Why did you replace it?
Once you get a matching set that stops that key symbol from flashing, you can concentrate on getting the car to run.
Get a bus pass?
Pray?
Walk away calmly, act like you were never there?
Cry?
Tow it to the dealer?
Push it off a cliff?
Tell your brother what happened?
Walk.....
LOL
Just put the ECM back in and see what happens.
Old Jan 18, 2014
00ACE00's Avatar
Car has beeen sitting for a few months under cover because my brother was putting in a junk2 intake and u had to unplug ecu so rpm could be right and ****, somehow it messed up car, had no power and all these engine codes came up, took it to a shop he ran a machine on car and fixed the ecu,i drove the car and stalled in first gear and car won't start, its doing the same thing but i got to put ecu back in i don't think it did the key thing. The guy couldn't fix car and said it was ecu, so i bought one from a guy that was parting out his 07 SI
Old Jan 18, 2014
00ACE00's Avatar
Anyways it won't crank even with the original ecu, why else would i be on here, only way is to push the car and pop the clutch
Old Jan 18, 2014
00ACE00's Avatar
My brother knows the car isn't running, this happened a few months ago lol, he left town and thought ecu would fix problem so i wanted to surprise him
Old Jan 18, 2014
Don't get all upset just because I don't already know what you didn't tell anyone here about the car.
Your thread went from sounding like you borrowed the car for a day, to now what sounds like this thing has been all apart sitting under a tarp for the last 6 months or something.
Hell, I ain't psychic. I thought this would be a completely stock car.
You stuck in a stock ECM:
Any used, stock ECM is going to be looking for the key that it was married to before it will let you start the car.
The ECM disables fuel when it does not see the correct chip key data.
These ECMs have been damn reliable. I wonder if your guy couldn't figure out the real problem and blamed the computer just so it would go away.
Did the car have a modified ECM or aftermarket ECM to go with the engine mods?
You have a different problem.
Even if it is in theft mode, the starter should still be able to engage.
From the service info:
If you try to start the engine without a
programmed ignition key, the engine cranks and may
start for a moment, then stall. It may only crank and not
start if the key was turned slowly, and the immobilizer
light flashes until the ignition switch is turned off.
I'm still not clear on whether or not you got the key symbol to stop flashing when the original ECM was reinstalled.
If you could push start and get it to run while that green key light is flashing, then something must not be stock.
Old Jan 18, 2014
What codes does it have stored right now?
Can you access any systems other than the engine computer?
Old Jan 18, 2014
Starter:
There should be a single wire connector stuck to the bracket on the battery tray where a red wire connects to a black/white wire. This is the wire that engages the starter solenoid. I would check there and probably begin my first electrical starter test there.
Old Jan 18, 2014
00ACE00's Avatar
Oem ecu back in
View My Video
pic of car
Will he took it to Honda day in September been fine ever since end of Nov. when i stalled in first, been like this ever since then. He has another car that he Daily Drives so he didn't really look into this problem yet. I thought maybe all the bumps i went on made the ecu finally fail since its slammed.
Old Jan 18, 2014
00ACE00's Avatar
Umm for the engine codes, i have no idea have not checked them in 4 months
Old Jan 18, 2014
00ACE00's Avatar
Stock engine, only thing its has is a buddy club full exhaust, aem intake,exedy stage 1 clutch,exedy fly wheel, and i think that is all
Old Jan 18, 2014
Oem ecu back in
View My Video
pic of car
Sweet looking lineup!
Hard to hear your video on this laptop...... Is the starter motor spinning when you hit the key, but not engaging the engine?
(I think i hear it whir like an electric motor freewheeling, but no engine cranking. If I'm hearing that right, it needs a starter.)
Again, those ECMs are damn reliable. Don't fear having the car slammed.
I see in the video now the green key symbol now stays off, so you must have the correct key+ECM set. It should run if all else is right.
Now you gotta get it to crank.
Old Jan 18, 2014
00ACE00's Avatar
something spinns but it doesn't crank, i called my brother to ask him and he said the guy said its ur starter,harness,and ecu.
Old Jan 18, 2014
00ACE00's Avatar
but its not the ecu, car would of atleast start with the other ecu right?
I'm try to trade this ecu for the guys starter if he will let me, How much u think i should pay for his used starter if he doesn't let me
Old Jan 18, 2014
Needs a starter.
It can't be all 3.
Pick the starter for the no-crank.
You said this thing runs if you push start it, so I seriously doubt wiring or ECM.
Unless I missed something?
There's a huge difference between cranking and running.
The starter has to crank it first.
The ECM controls the fuel injection and spark to get it running.
Whatever he wants, as long as it's less than a new one?
Look on parts store websites for a starter price...
For comparison, a reman starter from Honda will be around $300 list.
Or 210 plus shipping from Majestic http://www.hondaautomotiveparts.com/auto/jsp/mws/srchrslts.jsp?search=sku&catcgry1=&inputstate=&src hwords=31200-RRA-A51RM&vinnosrch=Enter+VIN+Number+---
Old Jan 18, 2014
00ACE00's Avatar
Alright, thank you for all your help, ill ask the guy tomorrow and see if he will trade or sell the start and ill let u know what his price is or if he just trades and when ever i get the start ill let you know if it runs
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
CiViCPrAnInG2k1
Jan 2, 2002 06:57 AM
black2k1vtec
Dec 6, 2001 09:49 PM
