Removing Outside Door Handle on 2008
Old Jul 16, 2013
moparmusclecars's Avatar
moparmusclecars is an unknown quantity at this point
I need advise! I know how to take the door panels off, the water shield, etc. I even know how to get the outside door handles off, and back on. I am just curious why it seems so hard to get the outer handle rod detached from the joint bushing. They seemed to be pressed in really hard, and I use a hook tool to remove them, but at times it lets the handle rock (spring area) and breaks the little center pivot plastic rivet head off which holds everything together. How do you get this rod off without hurting anything? I have yet to figure this one out. Does someone make a special tool? I have done quiet a few of them, and they are always a pain in the *ss to get off. Thanks guys!
Old Jul 16, 2013
CraigW's Avatar
Re: Removing Outside Door Handle on 2008
I lucked out on my 05 and there was another clip to get the rod loose. (actuator replacement)
Some sort of light lube maybe ??
MamaBear2015
May 18, 2015 07:37 PM
vgon24
May 12, 2015 09:16 PM
ROBREALZCIVIC
Dec 19, 2001 06:57 PM
Cypher
Dec 15, 2001 07:25 PM
rallyred2k1civic
Dec 8, 2001 11:49 AM
