- 2007 Civic. Quick query about cold starts/reversing
- 08 Civic Doors locks problem
- 2011 Civic idle goes up when turning steering wheel
- Clunk in front of 06 Civic Coupe EX
- Standard 2008 civic ex vtec?
- check engine light
- Cabin Air Filter Aftermarket Replacement
- Oil smells like gas, 2010 Civic
- 2009 Civic EX Making Strange Noise When Starting - Video
- back again
- 08 civic with dead battery cant shift to neutral.. Help please
- 2007 Honda Civic Si blower motor/lights
- 07 Civic EX Starter or Fuel Pump ?
- 06 Honda Civic Si - Trunk problem
- New 2007 Civic, Few problems
- Very Hard Power Steering
- 2008 civic - new owner - few questions
- Any thoughts?
- "Tighten Fuel Cap" message--how do I fix this?
- Easy fix for trunk leak
- Power Steering Fluid
- Jerky transmission, rpm problems, and poor gas mileage.
- AC problem 07 civic si
- ac trouble clutch wont come in
- Honda Civic SI Cold Air Intake Problems
- Car cutting out when pedal is Down to the floor?
- 09 Civic heater/ac blower not working
- Rough idle after valve clearance adjustment.
- Auto Transmission Fluid Change
- 08 Civic - Is my engine missing two bolts?
- No Ignition spark- please help
- A/C and blower works intermittently
- FrUsTrAtEd......
- Driver side speakers sound blown when iPhone plugged into Aux...
- DTC code 33-10 side curtain air bag???
- 2005 Civic automatic downshifts in high gear
- Spark plug question
- AC Blows Low On High Setting
- Code P2646 on my 2006 Honda Civic si
- OBD interface ?
- Batt Or Alt
- help please (codes not reading)
- 2006 civic issues !!!! Please help !!!!!
- Honda Civic 2009 looses all electric power the moment it's turned off! Any bulletins?
- Transmission flush--really necessary??
- 2006 Civic Ex coupe, missing at low RPM's
- bad input shaft bearing bad?
- Service oil life 5%...solved...or not ??
- Vibration problem
- 2011 Civic LX
- Engine Starting Problem
- Side Mirrors
- 09 Civic: Sometimes NO reverse?
- How to clean spark plugs? and which ones to clean?
- Help Wanted! - Need all the help I can get
- Turn Signal
- a drive belt causing misfire p0300
- Vibration--Engine Mounts???
- 2007 Service Manuals Online
- 2008 Honda AC blows cold air on and off
- new 2011 SI Sedan Rev Hang?
- 06 Civic Engine Noise
- 06 civic..p0128...how to test ect1 and ect2 sensors
- 2006 Civic SI
- 2009 Honda Civic EX issue Need Opinions
- A/C making weird noises
- 2010 Civic Manual, Fuel Efficiency decreased heavily
- 2009 Honda Civic EX Sedan Low Idle Problem
- Loss of MPG
- 2007 ac problem
- 8th Gen 5 speed transmission fluid?
- Slight Hesitation or miss?
- 2011 Si surging
- 2006 Honda Civic - wiper arm removal
- '11 si
- 2011 Honda Civic
- Need diagram for fuse box underdash
- tire pressure light stays on
- 2010 civic Ex auto 1400rpm low freq vibe
- CD Player Not working
- 2011 Not coasting/decelerates immediately
- 08 civic LX - auto trans - Intense vibration b/w 27-30 and 35-40 mph
- Whining noise in my NEW civic
- Third Brake light problem
- Honda Civic 2010: Key Gets Stuck in Ignition
- Nice New Starter, Strange New Noise
- Power Steering Gear Box and other defects
- high mileage 2006 Civic
