08 civic with dead battery cant shift to neutral.. Help please
Rep Power: 0 08 civic with dead battery cant shift to neutral.. Help please
Hi, the topic pretty much says it all. I just want to get home and i cant get a jump because it wont let me put the car in neutral... left the car dome light on and im screwed. please help!!
Re: 08 civic with dead battery cant shift to neutral.. Help please
There is a little bitty oval shaped cover in front of the gear shifter, just to the right side where you can't see it very well from the drivers seat. Pry it out. Stick a key in the hole and then you can move the shifter.
This info should be in the owners manual. There is lots of handy info in there.
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Rep Power: 163 Re: 08 civic with dead battery cant shift to neutral.. Help please
Why do you need the car in Neutral to get a jump?..if its in park you are fine..Just hook up the jumper cables and start your car...
CarStuff
12-06-2020 12:52 PM
tylerginevan
04-27-2015 12:29 PM
twtron
04-17-2015 12:09 AM
SSMatey
04-13-2015 06:09 PM
