DTC code 33-10 side curtain air bag???
Old Nov 7, 2011
epoxypatch's Avatar
epoxypatch is an unknown quantity at this point
Hi all,
2007 civic dx 50k miles . The SRS light comes on intermittently, esp. when going over bumps. Once it cleared itself, the other time I had to get it cleared by a dealer because it was on for 3 days. Does anyone have this issue? Any help would be appreciated!
Old Dec 3, 2011
Re: DTC code 33-10 side curtain air bag???
Let me get this straight.....you took it to a dealer and they only turned the light off, without fixing the problem? No wonder the light is back on.
Intermittent electrical problems suck to find, because it has to be faulty at the time of checking it in order to find it.
33-10 is an open circuit in the drivers (Left) side curtain airbag inflator.
The connector is behind the C pillar interior trim (rearmost roof pillar, next to rear window) on a 4 door car. The connector should be behind the side bolster of the rear seat on a 2 door car.
2 wire connector, and SRS wiring has yellow everywhere.
My guess is that if you unplug and reconnect the wire harness connector several (5 or 6) times, the code won't come back for several months. In this instance, I apply a product called "Stabilant 22A" to the pins. It is a contact enhancer. The wiring also is connected to the inflator unit itself--(most use a tiny plastic connector instead of embedding the wires directly inside it), and that is another place I see intermittent problems. Stabilant on those pins too.
If that doesn't solve the issue, then you could have a wiring issue anywhere between the inflator and the SRS control unit. Many possibilities there.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
usajags84
15
Aug 19, 2015 03:12 AM
Bigdaddy198
Apr 30, 2015 08:36 PM
