Break light on the driver passenger side does not work
Folks,
when my lights are on and i step on my break, the break light on the driver passenger side lit/works but when my lights are off and i step on my break the break light on the driver passenger side does not work, any idea?
thanks
thanks
Re: Break light on the driver passenger side does not illuminate
just to clarify:
1. when the lights are on the break lights are lit, but when i step on my break my driver side "break light" does not illuminate.
2. the passenger side and middle break lights illuminate when i step on the break pedal even if the lights are on and off.
i reseated the cable attached to the bulb assembly just for the sake of it - yet no luck.
i dont think its an issue with the fuse, break switch or the bulb itself.
im also in doubt if its a broken wire, why would the all break lights lit when i turn on the lights?
why does the driver side break light not illuminate when i step my break pedal?
any ideas will be appreciated...
thanks once again..
thanks once again..
Re: Break light on the driver passenger side does not work
In the same bulb, you have a dimmer taillight filament that's on when headlights are on. And a 2nd brighter filament that comes on with brakes applied.
From what I can gather.... you have a open brake filament on drivers side.
Take the problem side bulb out and look through it, make sure BOTH filaments are intact between the ! ! <<- (across wires standing up inside bulb)
Compare to working side.
You should change all 3 at same time.
thank you CarigW, i appreciate it...
i will follow your advice and will keep you posted.
CraigW - thank you so much..i followed your advice and it worked. the passenger side rear break light bulb is the culprit .. change all the bulbs..
MamaBear2015
May 3, 2015 02:17 PM
