1999 Civic Si EM1 Running Rough Idle with CEL
Old Jan 13, 2013
Dchampn's Avatar
Dchampn is an unknown quantity at this point
New to the forum but I've had a problem lately with my 99 Si. I'm getting a CEL code of misfire 1, 2, 3, and 4 also multiple misfires. I've replace the distributor with an oem replace, adjusted valves (none were loose), cleaned injectors, replace fuel filter, and sprayed IAC valve (idle was still rough after this). Idle is rough, engine shakes when accelerating but this all only happens when at normal operating temp. When cold idle is fine and not flucuating, but once warm it runs horrible! Please help lost what to do next
Old Jan 13, 2013
go-part's Avatar
Former Sponsor
go-part is an unknown quantity at this point
Re: 1999 Civic Si EM1 Running Rough Idle with CEL
I would suggest getting those codes read before you go replacing parts.
Looks like your issue is timing related..
Old Jan 14, 2013
Dchampn's Avatar
Ok I'll gather the codes and get back to you with them. If the timing was off what do I need to do to fix it, just get it retimed?
Old Jan 14, 2013
Dchampn's Avatar
Also when warm and fluctuating idle and active misfire the misfire stops if I turn the heat on or give it a little gas to hold the RPM around 1200. When I do that it smooths out
usajags84
15
Aug 19, 2015 03:12 AM
usajags84
May 10, 2015 08:11 AM
Pr0n1s
Apr 30, 2015 03:08 PM
rcolosi
Apr 29, 2015 07:48 PM
aultman1990
Apr 19, 2015 07:14 AM
