Can someone please help me with my civic
So anytime I'm idling and my fan comes on the RPMs drop to roughly five to six hundred RPMs and anytime I put the window up as well when I idle it also drops to the same RPMs as when the fan kicks on. What could it possibly be? Is it my idle air control valve?
Re: Can someone please help me with my civic
Get the alternator (ouput voltage) and battery checked at Autozone or other parts store. Both can be tested without removing either one. Here's a related read (Nissan): http://www.nissanclub.com/forums/gen...g-bad-yes.html
Year/Make/Model/Engine/Trans?
Idle rpm can dip when a large electrical load occurs. Idle speed should recover and stabilize right away though, as long as the load is stable and steady.
Maybe idle relearn could help
There is no idle air control valve. The car has electric throttle.
YES sudden heavy (high amperage) electrical loads can cause the engine RPM to dip briefly and lights to dim.
Pulling on the window switches will make the headlights dim a little bit, that's normal.
AC and radiator fans kicking on will make the headlights dim briefly (but engine RPM should stay pretty steady as the ac compressor and fans cycle repeatedy).
If you try to clean the throttle body you could bring on more problems than you started with.
IMO about all you can do is confirm no other problems causing low RPM (No fault codes? Air filter box lid not installed correctly? Air filter gasket not rolled off the edge?), then try an idle relearn procedure.
OR maybe what you notice is normal for the car and not a problem at all....?
Most people don't drive around pulling on the window switches all day long. Just at the end of their drive.
tallal565
Jan 9, 2013 06:18 PM
slammed2k2
Feb 23, 2003 04:53 AM
