2009 Civic LX - a/c issues
I have a 2009 Civic LX 1.8L FI SOHC 4cyl with which I am experiencing intermittent a/c issues.
Symptoms: intermittently blows hot air when a/c is on, when a/c is turned on the compressor/clutch engages and rotates for a second, then stops and repeats, when the a/c is on the entire car shutters intermittently.
Repairs: I have recharged the a/c, and replaced the compressor clutch relay - neither have fixed this issue.
Note: Both fans engage and seem to be working normally.
After doing a lot of research online, I'm wondering if it could be the a/c low pressure switch, or maybe the compressor/clutch need to be replaced entirely?
Any recommendations, referrals, or advice is greatly appreciated!
Thanks
Thanks
Re: 2009 Civic LX - a/c issues
However, I was experiencing the intermittent hot air issue before charging my a/c, and I don't believe this to be the main or only issue...?
Low side pressure alone can't show this.
It's a tiny system. A single can of freon can overcharge it. (A majority of of the AC problems I see have nothing to do with freon level)
Check clutch air gap.
The legs in the public bathroom stall
You need to be able to check the high side pressure (running) to determine if it's really overcharged.
Maybe....but now you probably added more problems to the original problem.
Can you point me in the direction of any instructionals showing how to check the clutch air gap? I found a write-up on a different post, but it is for a 2001 Civic. Should I just take the entire compressor out and give all components a good inspection?
Visual inspect by watching it operate.
Texas_Civ
Mar 15, 2017 09:34 PM
stevedub
Jan 6, 2017 07:59 PM
TheUman
Feb 20, 2015 07:53 PM
Stonegenie
Nov 16, 2010 08:03 PM
dougjr99
Sep 18, 2008 03:21 PM
