Roll Bounce!
Old Nov 27, 2018
HondaHunny0512's Avatar
HondaHunny0512 is an unknown quantity at this point
Post Roll Bounce!
Hey hey - so I'm new here but figured I'd give this a go before calling 20 different shops all around town. I have a shitty sense of humor so I'm gonna apologize for that one up front - and the novel - I'm terrible with stories :blablabla:
Aaaaanywho here goes - I have a 2011 Honda Civic LX (black beauty AKA my baby). We recently got about an inch of ice topped with a few inches of snow. My poor black beauty got stuck in the middle of the road in my neighborhood when trying to move it. I (admit-tingly) was an idiot and kept flooring the gas pedal turning wheels all different ways - reverse & drive - went from regular drive, to D3 to 2nd gear - none of it made a difference. So a few friends helped push so it wouldn't be stuck in the middle of the road all night. When driving today I noticed a slight bounce/shake, didn't think anything of it, figured there was still ice on tires or snow or on the road itself. As I keep driving (roads are now clear **for the most part**) the bouncing and shaking continues as if I'm driving down the road in Radiator Springs before Lightening McQueen fixed it . Bounce in the car itself and shake in the wheel that matches the bounce.The higher the speed I go the worse it gets. I thought I may have had a flat tire but nope. No shaking when braking so pretty sure there's no rotor issues. After accelerating to a higher speed then letting off gas it still shakes/bounces even when down to 15mph but gradually lessens as the speed reduces. If I lightly press gas it doesn't start it's roll bounce until about 20mph+.....any thoughts? :help: :5shots:
Old Nov 27, 2018
Re: Roll Bounce!
lift car.
remove wheels.
inspect
otherwise, it's a small gnome that got stuck in between the brakes and the wheel and is screeching with the friction.
Old Nov 27, 2018
Re: Roll Bounce!
It's how cold there?
You got how much snow? How much ice?
Snow and/or ice packed in the wheels WILL make horrible shaking happen and it will continue to do so until you either remove the snow/ice buildup from each wheel, or it gets warm enough to melt it out of the wheels.
You can absolutely destroy the transmission by doing this. Literally destroy it, leaving solid steel and aluminum parts and a lake of transmission fluid scattered on the road under the car. Followed by calling a tow truck because it won't move under its own power any longer.
anephric
Feb 21, 2015 04:15 PM
WannaBFast
72
Jan 31, 2013 05:17 AM
tko
15
Jan 29, 2005 08:29 PM
Grey
Jan 5, 2003 04:35 PM
nrrhgreg
Jul 1, 2002 02:59 AM
