Accessory Belt Tensioner Loose
Old Jul 24, 2017
stootz97's Avatar
stootz97 is an unknown quantity at this point
2007 Honda Civic EX 4D Auto 122K miles. My Accessory Belt Tensioner is really loose. I'm not talking about the pulley, i'm talking about the actual tensioner that you put a wrench on to loosen the belt. It's shaking and clicking like crazy. I'm also having a problem with my car jerking/dancing at idle so I'm hoping these are related. I bought a new belt today and going to throw it on even though it seems pretty tight/new. I just bought the car a few months ago so I'm not sure whats been done. I've only seen DIY's for pulley and belt replacement but can't find anything for replacing/tightening the actual tensioner. It's a tight squeeze and looks like I may need to pull some pulleys off to get to it to inspect. Any insight would great. Thanks
Old Jul 25, 2017
Re: Accessory Belt Tensioner Loose
Is the tensioner assembly (the arm that holds the smooth pulley), is the arm laying sideways? Making grinding noises?
If so, it probably broke the bolt in the center of the pivot.
If it's not laying sideways, if it's just shaking a lot, it could be caused by a bad belt or it might be a failing damper (that little shock absorber looking thing on the end of the tensioner)
Just guessing... You could put the 19mm wrench on the arm and see if it moves easily....it should be quite stiff as that little damper is pretty strong.
