2007 SI clutch replacement
Old Jul 19, 2017
Guitsax's Avatar
Guitsax is an unknown quantity at this point
Hi, I'm in the process of replacing the clutch on my sons manual 2lt SI ivtec.
My input shaft is 25.4 (1"). The replacement clutches either don't give that measurement or when they do it seems to be too much clearance. I'm looking at exedy k20. I've had 24spline 26mm , 1.1/32, 1.1/8. ?? What should the clearance between the hub and the shaft be?im assuming the 26mm won't be too loose?
