Zero Compression Cylinder 2
Old Apr 21, 2018
Hole-Man's Avatar
Hole-Man is an unknown quantity at this point
So I have a 1999 Civic Ex 5 speed and for the past year I’ve had an ongoing issue with a misfire code . First started off as random misfire p1399 and cylinder 1 and 2 . Changed everything ignition related and code went away , couple months go by and light comes and and starts flashing . Checked plugs , wires, cap , rotor everything checked out . Cleared the code and ran fine for a couple days than started having a rough idle . Code since has been reading p1399 and misfire cylinder 2 sometimes 1 . Been driving as is for 7-8 months no real issues no loss of power at full throttle/ Highway speeds. Recently ran a compression test with consistAnt compression in every cylinder but 0 in cylinder 2 . Other than tearing it a part am looking at a bent valve or bad rings ? Or something along those lines?
Old Apr 21, 2018
Re: Zero Compression Cylinder 2
Leakdown test is how we determine where the leakage is.
rhull
Dec 11, 2011 01:02 AM
NJPiineapple
Jul 26, 2011 11:20 AM
91civicsiproj
May 5, 2011 11:43 PM
civicgirl91
Apr 3, 2011 04:03 PM
laack
29
Jun 17, 2010 03:29 PM
