Replacing sunroof motor!!
Rep Power: 0 Replacing sunroof motor!!
I have a 06 civic and my sunroof is popped up, I'm looking for step by step on how to remove headliner and replace sunroof motor.
thanks
thanks
Re: Replacing sunroof motor!!
Don't make more duplicate posts, they end up as clutter.
Does the roof motor run at all?
If it runs more or less okay but during closing it skips the stop point and runs to the popped up position, the control unit just needs programmed.
Will it try to run one direction? Have you diagnosed a real motor problem? Maybe it's a switch issue, wiring, mechanical problem, or an obstruction?
To gain access: drop the headliner as needed:
Remove trim from each pillar, remove sunvisors and clips if you're going to drop the front end, remove chicken handles, remove dome lights and trims, remove everything in the way of dropping the headliner down far enough to locate and access the sunroof motor, then do it to it.
Rep Power: 0 Re: Replacing sunroof motor!!
The motor,doesn't make any noise when when clicking the open / close switch. I tried to reset it,holding it for five seconds or something along those lines but tried this ages,ago. Has to be the motor. Thanks for the steps, just wish there was a video showing them. I've nvr taken the headliner down.
Dretoven
02-09-2018 01:58 PM
wallydude03
16
05-02-2012 06:51 PM
hcivic0120
10-31-2006 08:37 PM
cmeghea
04-17-2006 08:46 PM
