View Full Version : Engine start problems
- 05 civic cranks runs then stalls after 2 mins
- 2001 Civic Starts & Instantly Stalls
- 03 civic no spark...
- ECT and IAT variance
- Hard/Long Start and Overheating
- 2004 Honda Civic crank no start after head gasket rebuild
- Crank no start
- Starting issue has fuel and spark
- NO crank and Weird Noise coming from glovebox
- 2004 Manual Honda Civic EX No crank No start
- not starting when engine is cold
- 04 Civic intermittent no start and dying while driving Help! No codes
- 02 civic LX coupe No start
- 2003 Civic Hybrid CVT 119k miles won’t start
- Car won't start
- Car won't start after cleaning fuel injectors
- No Crank No Start
- Won’t Start after it gets too operating temperature
- 05 EX no crank> therefore no start.
- Question on fuel pump pressure, hard start [solved]
- '04 Civic Crank, Intermittent no start
- 2002 honda civic cranks no start [solved]
- 02 civic ex not starting after cold weather
- 02 Coupe EX, no start, no radio, no blower
- Cold start problems
- 2005 Civic Won't Start (Has Fuel and Spark)
- Long cranking time, when starts runs fine.
- Car won't start rapid clicking noise
- 2001 civic crank no start
- crank but no start please help
- Clunky start then runs fine
- Smoke came out of steering column. Crank no start, and can't shift out of park?
- 04 Starting Issue [solved]
- No start no crank issues
- engine start and dies
- Runs for 2 seconds.
- Won't crank [solved]
- CRANKS but won't start!! Help
- 2004 Honda Civic ex no crank, wont turn on, neutral safety switch
- Newbie with No Start then runs great problem!!
- 80 amp blowing and Alternator white cable shorted [information]
- P1361 no start
- 2002 Civic Si Fuel Cutoff/ Inertia Switch Location
- 2003 Civic hybrid post repair issue [solved]
- 01 Honda Civic starts but immediately dies. [solved - timing]
- 02 Civic EX strange fuel starvation? [solved]
- 2005 EX Won't Start In Cold
- car stalls first attempt, starts second attempt
- cranks no start O2 sensor voltage high [solved?]
- 7th gen, whine no start
- Cranium
- Civic died and won't start
- New starter bad?
- 04 si rough start, dies after
- P1361 Code and Limp mode
- 01 Civic EX Cranks But No Start
- 05 civic cranks but no start,tried everything I think
- Starter spins, no start.
- How do i put an engine back into time after it has jumped timing?
- 2001 honda civic ex crank no start
- no crank, no start, no horn.
- Stalled Engine, Now "No Start"
- 03 LX standard civic rpm drop and stalling
- POP then nothing [solved]
- 2003 Civic LX Coupe Starter Relay Location
- 01 no start
- 2002 honda civic lx crank no start.
- No power/start 05 civic hybrid
- No crank No start.. starter just spins
- 04 Civic Won't Start After Overheating
- No crank No start HELP
- 1.7l hard to crank when warm
- Starting Problem
- 2002 honda civic starting issues
- 2003 civic problem HELP PLEASE
- 02 Civic LX no crank no start
- Honda Civic 2002 Won't start [solved - green key flashing]
- 01 civic no start on in cold temp
- 03 Civic ex will turn over, but will not start.
- Civic 2001 D16v1 no start when cold
- 2004 Civic LX will not start unless pressing gas [solved]
- Honda Civic 2002 (7th Gen) Cold Start Grinding Noise
- 2005 Honda Civic won't start (Solved)
- 2004 LX - Intermittant no crank no start
- 2003 honda civic sedan lx
- No Start Condition After Timing Belt Change
- Cranks no start
- 05 civic Starts and dies
- 2005 LX Coupe Manual Clicks But Won't Crank, Can't Remove Starter
- Hard start, runs fine, injector issue cylinder 3
- START THE CAR WITHOUT TURNING KEY 7th GEN
- 01 Honda Civic LX won't stay on
- Crank no start - *SOLVED**
- 2002 honda civic lx cranks but wont start
- Crank no start
- 2001 Honda civic ex start and stall Help
- Crank no start - ideas
- car won't start.
- Replaced cam sensor, still no run if connected
- 05 civic
- I’m at the end of my rope, please help...
- Headgasket replace now no start
- Cranking no start, everything checks good [solved]
- 2001 civic lx just died while driving
- 02 Honda Civic. I just replaced water pump and tuning
- Cranks but wont start
- 2001 civic ex sedan m/t
- 04 civic ex with 1.7l vtec and standard trans cranks but will not start
- No crank no start, bad starter?
- Crank but no start
- Battery is good, no power no start
- 2004 civic will not start
- 2001 honda civic lx coupe hard start when cold
- Won't start when could
- Crank but no start..
- Engine Stalls on Idle, won’t start after fueling up tank.
- Replaced Head Gasket, Starts, Then Doesn't
- Doesn't wanna start after driven.
- Cranks No start, hard start.
- Starts for a second then stalls
- 2004 EX Power but won't crank
- P0336 code
- Hard start when engine is hot
- Code P0171 and P1361
- Issues starting car only after you pump in gas
- Civic 2005 ES8 problem when starting
- Civic crank but no start
- Wont start unless I hold the gas pedal down
- Car will turn over but won't start
- Crank no start
- 01 civic no start when hot
- Engine won’t crank no fuel pump no starter no spark.
- 02 civic Crank, no start.
- cold start is fine, it’s when I turn the car off is the problem
- 2005 honda civic cranks won't start
- Civic starts but shuts down with the smell of gas
- 2001 civic dx no fuel no spark no crank
- Civic will not start
- key turns and lights come up but no start, no noise
- new to hondas
- 2001 Civic Cold Start fine then dies, runs fine after restart
- 03 civic won't start.
- 01 Civic. No crank, can pop start.
- Famous crank but no start
- 2002 Honda Civic won’t start
- 2002 Honda Civic EX No Start
- 2003 D17A1 no spark
- 2004 1.7 vtec turns over strong but wont fire
- Please help car starts but dies directly afterwards
- Civic 2005 cranks but wont start
- 2001 civic ex 1.7 cranks but wont start
- Intermittent Starting Issue
- new battery, new alternator and starter, car still won't start 2005 si
- Engine wont start
- Car turns on but shuts right off
- 7th generation Honda Civic no start no crank - information
- 2001 Civic Start Problem Please Help
- Starting issue
- Either starts perfectly or cranks only
- Starter Questions
- HELP - Car will not start after welding and installing exhaust manifold
- 2001 civic doesnot start without the OBD device
- Cranks but won't start
- 2001 Honda Civic LX Crank (standard Tran), No start condition
- 2005 Civic LX Intermittent Start Problem
- Randomly cranks over but doesn't fire.
- [SOLVED] Car Crank but won't start and when it does...
- Car wont start
- 2002 Civic No Crank No Start - Troubleshooting
- New user. Son's Civic won't start.
- 2003 civic wont turn over
- 2002 Civic. Good Battery. No Crank.
- 01 Civic LX crank no start
- Honda Civic 2002 Morning Starting Problem
- 2002 civic 1.7L will not start unless given gas
- Car just turns over but wont crank
- Starting issue
- 2004 rapid clicking but no start. will start when jumped
- starter problem?
- 01 civic no start
- 1 week I was away, 2001 Honda Civic Ex wont start
- Car Won't Start After Replacing Headgasket
- crank no start, not showing any codes
- 2002 civic EX 1.7 won't start
- Replaced Fuel Pump - Won't start
- 2001 EX main relay
- 2002 Crank no Start no Codes
- 2001 EX no crank no start
- 2001 won't start in the cold
- Car has Spark, Fuel, and timing but won’t start?
- 2004 cranks but no start
- 2001 civic LX Disaster!!!! - hard start
- 2002 civic ex wont start
- Car Won't Start on Hot Days or after making other stops
- my car won't start
- Does not start
- d17a2 won't start
- Car won't start - Civic Ex 04
- 05 civic sport no start problem
- Car wont start: passenger side of engine covered in oil
- Won't start Any guesses? [solved - headgasket]
- Need help with a civic that won't start
- Crank-no start and random acceleration
- Turn the key, doesn't even crank
- crank no start
- 2002 LX Crank but Won't Start
- Start sputter stall, P0335
- Might have a unique problem here....
- 2001 civic died on the highway
- intermittent crank but no start
- Starting issue
- car wont stay on
- crank no start
- 2005 civic starting and stalling issues
- Engine rotates but won't start.
- Car in anti-theft/ immobilizer mode, won't start?
- Cold Start Ok, Warm Start not ok.
- stuck crankin' and wont starting.
- Car not starting
- 02 EX - Replaced fuel filter, won't start
- Civic 2003 VTI Starting problem
- starts then dies
- Need help em2 wont start
- Car won't start - Is it the starter?
- Bad fuel pump?
- 2002 civic ex... car wont start
- My car wont start anymore
- P1362 and no start
- 01 Civic Ignition and ECU Replacement Troubleshooting
- 01 civic ex won't start..good spark
- My honda civic si 2004 giving difficulty to start :-( please help
- car doesnt go, checked everything...
- 2002 Civic No Start
- Car won't start!!! PLEASE HELP!!!!
- stupid car wouldnt start
- stalled and wont start- glowing cat
- help p1519 won't start
- intermittent starting Problem
- car don't start
