Engine start problems Post issues with engine start here. Does not start, does not run, etc.
05 civic
Old Jun 17, 2021
bruce levack's Avatar
bruce levack is an unknown quantity at this point
05 civic
I have a 05 civic si 1.7 vtech that won't start. My scanner reads P0141.02heater circuit (Bank1, Sensor2). In the FF it reads Fuel system 2- CL Fault. I would like to know where the sensor is so i can replace it & will my scanner reset the fault. Any help would be appreciated. Thanks
Old Jun 17, 2021
Colin42's Avatar
Re: 05 civic
So it cranks but doesn't start?
got spark? Fuel? Compression?
Old Jun 17, 2021
Re: 05 civic
Hi Tks for responding. I have even comp. Plenty of fuel, I put new plugs in but I dont think i'm getting spark. I replaced the temp sensor in the air cleaner & that cleared the first code but not the fuel 2 fault. The new code came up after I tried starting it. I've cleaned the plugs again & put a little oil in each cly. All the gas washed out the rings. Tks. again Bruce
Old Jun 17, 2021
bachands's Avatar
bachands is just really nicebachands is just really nicebachands is just really nicebachands is just really nice
Re: 05 civic
A restricted exhaust perhaps? You could try removing the front O2 sensor and see if the car will start then.
xdee716
Feb 14, 2023 03:32 PM
Spoon Racing
Jan 2, 2006 07:06 PM
Spoon Racing
Jan 2, 2006 01:54 PM
kelvin1262003
Dec 28, 2005 01:52 PM
bluesi05
26
Apr 11, 2005 08:22 PM
