Engine start problems Post issues with engine start here. Does not start, does not run, etc.
Replaced cam sensor, still no run if connected
Old Jun 26, 2021
tailgunn's Avatar
tailgunn is an unknown quantity at this point
Have an 04 1.7 liter that would crank but die after a second. It would run fine if the CPS was unplugged, so I figured that was the problem. Just put in the new one and the same thing. If I unplug it, runs fine. We did just put a new water pump on it because the old one had 12K on it and was leaking ( timing belt was done at a shop I will never go to again ). The belt looked completely fine, so we only did the water pump. The alternator is also new. It ran fine for a couple of weeks after we did all this work and then this started. It runs fine so I don't feel like the timing has jumped. WTH?
Old Jun 26, 2021
Colin42's Avatar
Re: Replaced cam sensor, still no run if connected
What brand is the new sensor?
Old Jun 26, 2021
tailgunn's Avatar
Dorman
Old Jun 26, 2021
FRSam's Avatar
Click Here
Originally Posted by tailgunn
Dorman
Needs to be Denso or directly from Honda.
Old Jun 26, 2021
tailgunn's Avatar
Well, phooey.
Old Jun 26, 2021
Colin42's Avatar
Go to a junkyard if you don't want to pay full dealership price
Fuego
Oct 22, 2023 08:18 PM
oldbeater
Oct 13, 2017 05:07 PM
franciz3
Jun 20, 2017 09:12 PM
NewtonsAroo
18
Sep 8, 2013 11:55 PM
EG06KRS
Oct 9, 2007 01:55 PM
