Engine start problems Post issues with engine start here. Does not start, does not run, etc.
intermittent starting Problem
Old Oct 7, 2005
Bigfella's Avatar
Bigfella is an unknown quantity at this point
Occasionally when i start my car, it will turn over but not fire, it has done this about three times in three months. But lately its done it twice in two days. Does anyone elses do this, or does anyone know whats wrong. Just with winter coming in the UK dont want to get stranded. Seems to be getting worse??????
Old Oct 7, 2005
streetglower's Avatar
when it happens, does it start after a few tries, or does it crank for an extended period of time then start?
Old Oct 7, 2005
Bigfella's Avatar
Usually starts after about third go. Car is 01 Civic 1.7VTEC forget what you guys call it over there?? Just getting worse. Most of time it starts first time.
Old Oct 7, 2005
southpasdena's Avatar
Super Member
southpasdena is an unknown quantity at this point
i got a similar problem on my 04, once in a while it is cranking for like 5 sec before the engine actually starts
Old Oct 7, 2005
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
I have the same problem in my 02 does the little light in the cluster that looks like a key flash on the dash while its cranking? If so its because your immobilizer cant read the transponder in the key. You dont need to crank it for an extended period of time. Just pull the key out then put it back in and try again and it will start
Old Oct 7, 2005
well for either problems wether it be long cranking then it starts or it cranks and cranks, then after the third try it will finally start could be caused by a number of things. First do a visual inspection of the battery connections, ignition coils, fuel injectors and make sure nothing is loose or corroded.
You may have a fuel delivery issue, ignition problem, vacuum leaks, something clogged. Its really hard to say. You have to run some tests to determine what it is. If it cranks for an extended period, then starts, you may be losing fuel pressure. Either through the a injector staying open or a fuel pump check valve that has failed. I am not sure how many electric fuel pumps have check valves, I have been told only mechanical pumps do, then others say electric ones do, so someone with more experience would have to answer that. An easy check on that would be too hook up a fuel pressure gauge and see if the rail holds pressure. If after 20 minutes the pressure falls to 0, something is leaking. Could also be a bad ignition component.
Now also to help with the no start for several times, when it happens, check for fuel and spark during the times it happens. If you have an intermittent no spark during those times, then you know its a ignition problem. No fuel means a fuel problem. then go from there.
But check all the obvious first, check the air filter, spark plugs.
that too. I always forget about the immobilizer unit.
Old Aug 4, 2019
Wistech100215's Avatar
Wistech100215 is an unknown quantity at this point
Re: intermittent starting Problem
I just had my 158,000 mile 2005 civic ex special edition do the same warm no starting randomly, I bought about four mouths ago it has a new 1-18 battery and new alternator someone else installed do the same thing, I replaced the spark plugs. But the Random no starting didn't go away until I cleaned all the main grounds up under the hood, The Negative battery cable connections, Note The engine would turn over every time but would randomly not start. This was very frustrating when in a hurry to go to work etc. Also this car would always start after it was shut off for over two to three hours or cold, thanks good luck everyone..
Old Oct 12, 2019
UPDATED 10-12-19 after a few weeks this problem came back this time it would not start at all, I found the problem to be someone spread the three female pins apart in the engine harness plug for the crank sensor I started watching the engine rpm data with the fixd app I was using on my android cellphone noticed that the engine rpm data was very erratic or none causing a random no start, so to fix this I cut a map sensor plug off of my 2003 civic hybrid parts car that is the same plug then used solder seal connectors installed that for a good plug now it starts better than it ever has also the one female plug pin with the blue wire was green like salt water corroded it.
Old Jul 21, 2020
sinkenken's Avatar
sinkenken is an unknown quantity at this point
I had a problem from brand new 7th Gen car with 1.7 motor.
After running for a while and stopping engine, say for gas it would crank but was hard to start.
Last year on really hot days the engine would just stop intermittently for no reason and after about 10 minutes I could start it normally again.
Eventually found the problem was the TDC Sensor failing with heat soak at garage or during really hot weather (>38deg C)
Old sensor had J5T23991 2509 PLC written on it.
I replaced it with 37840RJH006 Sensor from Honda which Supercedes J5T23991 2509 PLC
It was showing Fault Code P1361 when it was failed and hot.
Hope this helps.
Old Jul 1, 2023
Sexileomama's Avatar
Sexileomama
Sexileomama is an unknown quantity at this point
Thank you for the advice!! I have a 2006 Honda Civic. I noticed the last two days it takes longer and longer each time-to actually turn over and start. Replaced the starter 2x, all new ignition…..coils were replaced about a year or two ago. Same w/spark plugs??
Thank You!! ; )
Old Jul 2, 2023
Colin42's Avatar
Battery?
fd59
Feb 19, 2014 01:09 PM
fahadlovely
Oct 11, 2007 08:32 AM
ndskimr
Aug 12, 2005 02:00 PM
gearbox
30
Apr 3, 2005 07:14 PM
jkim1978
Oct 15, 2002 03:28 PM
