Engine start problems Post issues with engine start here. Does not start, does not run, etc.
No crank no start, bad starter?
Old Jan 29, 2021
leok99's Avatar
leok99 is an unknown quantity at this point
Got a random no crank no start problem and I only hear one click from glove box I think it's the main relay, absolutely nothing on engine bay.
Dash has power and all interior power cut off when turning the key(as expected).
And it starts right up after tapping the starter with a hammer lightly.
So looks like a bad starter. I'm thinking of repairing it myself, and seems that there're two types of repair kit:
for brush and for solenoid.
So how do I know which is correct kit?
I'm now considering replacing the whole starter if it's the issue(hopefully).
Any suggestion on Denso vs Store brands?
Denso is 1 year warranty store brand is lifetime.
Thanks.
Old Jan 30, 2021
Wankenstein's Avatar
Re: No crank no start, bad starter?
I usually pull (Honda OEM) one or have on pulled from local salvage yards. Generally between $25-$35 and no concern about fitment. They check them with a battery and jumper cables prior to payment. Usually, at least a 30 day warranty/full replacement.
Part store starters are usually rebuilds that have a new brush kit and perhaps a new gear.
Old Jan 30, 2021
leok99's Avatar
My local LKQ wants $30 for starter, same price as ebay's OEM pull.
My starter has a failing solenoid but I'm sure it can still pass bench test, as it fails like once every 20 starts.
But the solenoid is sealed and can't be dissembled...
Options:
new TYC starter from amazon $90 no core charge + 1 year warranty
denso rebuild: $100 + core charge + 1 year warranty
store brand: $90(AAP) + core charge + lifetime warranty
Old Jan 30, 2021
I've been fortunate with used OEM parts so I generally lean in that direction. Save $60-$70 dollars would be to tempting for me.
Rather do local than any returns that involve shipping. Just.my 2 cents.
Old Feb 6, 2021
leok99's Avatar
Update: got a starter from AAP and replaced it today.
Fairly easy job, lots of youtube videos. Had to use breaker bar for one of the 14mm bolts though.
The new starter sounds differently than the OEM.
OEM starts right away, this starter will spin for a split of second then starts the car.
One thing worth noting, while the the solenoid is not serviceable, it can be replaced.
About $120 for OEM and $20 on ebay. That's the cheapest option but I have no confidence
on ebay parts so I go with store starter instead.
Old Feb 6, 2021
Hold on to that lifetime guarantee receipt, you're going to need it..lol. Just messing with you. Should last a couple years hopefully.
Gold to hear you got it straighten out.
DaBrother
15
Mar 7, 2020 05:36 AM
chozobody
May 28, 2014 05:47 PM
2003civlxhockey
Florida
Jan 22, 2014 07:20 PM
xylerium
Oct 31, 2011 09:32 AM
fallout
May 7, 2007 08:27 PM
