Engine start problems Post issues with engine start here. Does not start, does not run, etc.
Starts for a second then stalls
Old Sep 20, 2020
Dic tiaiter's Avatar
Dic tiaiter is an unknown quantity at this point
My 04 civic lx was overheating so after changing the thermostat, water pump/ timing belt, and the two coolant sensors by the thermostat I was still getting bubbles out of the radiator. Last thing was the head gasket. 3 days later , everything put back together and it starts for just a second and stalls. I saw a thread on here but I cant find it agai . Anyway it led me to unplug the crankshaft position sensor as a test so I did and it kept running so my dumb as waisted anthrax 75? On a new crankshaft position sensor that I didnt need because it only stays running when Its unplugged. so my question is why ? Ý6 dose that mean that it will only remain runnigngh when that sensor Is unplugged in
Old Sep 20, 2020
Colin42's Avatar
Re: Starts for a second then stalls
Timing is correct? Or did you install an aftermarket sensor?
Old Sep 20, 2020
Green key flashing rapidly when it stalls? diag immobi
Sets new fault codes? Follow codes.
No codes? cam-crank out of sync (timing wrong)
Old Feb 11, 2021
Goldy63's Avatar
Goldy63 is an unknown quantity at this point
Did you ever find out what was wrong? My 2001 Civic is doing the same thing. Broke timing belt 6 or 7 months ago so had to do a head job with all new valves. Been running great up until last week when she just shut off on the highway. Will run for a second. No codes. Towed home. Will stay running with Crankshaft Pos Sensor disconnected. Haven't tried driving like that but sounds great idling and racing engine. Plug sensor back in and shuts off after a second. Any help would be appreciated.
Old Feb 11, 2021
Colin42's Avatar
So something wrong with the sensor, check the wiring, connector, if all looks good change the sensor, do not use an aftermarket sensor, get one from a junkyard if you don't want to pay what the dealer wants
Old Feb 12, 2021
follow this
Old Feb 12, 2021
Goldy63's Avatar
I don't have the green key light flashing. I'm going to check the crankshaft/camshaft timing before I replace the CKS. After I did the head job last year and replaced the timing belt, tensioner and water pump I've had an oil leak. I installed new seals but must have damaged one. Will post on what I find out.
Old Mar 1, 2021
Goldy63's Avatar
So I found out it did jump a tooth on the timing belt. The oil leak was coming from the valve cover too and not the cam or crank seal. When reinstalling stripped the threads on the tensioner. Damn. Was able to install a helicoil but it was difficult due to no room. Seems to be good so far. Didn't see anything wrong with the tensioner or belt. They were only 6 months old. Suspect oil from the valve cover gasket leak may have gotten on the timing belt and allowed it to slip. What are you guys thoughts?
Old Mar 1, 2021
wait and see
Old Mar 1, 2021
Colin42's Avatar
Aftermarket or OEM parts?
Old Mar 1, 2021
Goldy63's Avatar
I bought a premium kit on Ebay. The water pump was Aisin brand, and the timing belt is Evergreen Racing. The tensioner is GMB. So aftermarket. Thought I was getting good ****, but maybe not so much. We'll see. Keeping my fingers crossed. Shes got 253,000 on her so far.
Old Mar 1, 2021
FRSam's Avatar
Click Here
Evergreen is crap. Get a Gates belt. It's like $15. Aisin water pump is fine.
Old Mar 1, 2021
Goldy63's Avatar
Thanks for the info on the Gates timing belt.
Old Mar 1, 2021
FRSam's Avatar
Click Here
No problem. Gates is actually the OEM for the Honda timing belts/water pumps, so remember that for future reference.
Tutty6
24
Aug 31, 2017 03:35 PM
fort_em2
Mar 1, 2017 05:35 PM
Formergijoe
Apr 8, 2015 12:29 PM
leblanc
Ottawa
16
Oct 23, 2012 08:26 PM
lame05
Nov 9, 2011 11:36 PM
