Coolant temp sensor
Old Nov 7, 2011
lame05's Avatar
lame05 is an unknown quantity at this point
Coolant temp sensor
Ive been having cooling system problems with 05 ex. Im basicly down to head/Hg but recently i've been haveing issues with it warming up just idleing so i checked the coolant temp sensor and at max temp that i could get it to at idle the resistance reading on the sensor .1 ohms but at running temp after driving 2 miles it 253 ohms does anyone know the actual spec for it?
Old Nov 7, 2011
Re: Coolant temp sensor
huh just checked the honda manual and no sign of how to test it. im guessing its one of those replace when bad parts. the engine light should come on if the sensor is out of spec. it is a simple thermister (temperature sensitive resistor).
Old Nov 8, 2011
04 Honda Civic's Avatar
Its probably not your head gasket. Are you overheating? Change your thermostat if your car is taking a long time to warm up. Should fix your problem.
Old Nov 9, 2011
lame05's Avatar
I didnt check it with a procedure from the manual i just shut the car of unpluged it and used my dvom to measure resistance.Thermostats been changed and so has the waterp pump. the car only overheats if Im sitting idleing for to long or for what ever reason the car decides to dump all the coolant in to the overflow tank and wont suck it back in.
Old Nov 9, 2011
did you change the coolant recently, and if so did you bleed out the air bubbles?
Old Nov 9, 2011
lame05's Avatar
yes i chanbed the coolant and i did bleed the system.
Old Nov 9, 2011
im not even sure what the problem is. if its slow to warm up at idle, thats normal. cars are supposed to warm up while driving. in winter, the car will likely never warm up sitting still. now if it takes a long time to warm up while driving, its prolly the thermostat. ECT sensor the engine light will tell you its bad.
Old Nov 9, 2011
anibis's Avatar
anibis will become famous soon enoughanibis will become famous soon enough
When I changed my coolant the other day it took my car 15 min to reach operating temp on a 60 degree day. This was with revving on occasion to help bleed the system. I had to turn off the heater because it just wouldn't warm up.
Are (or were) you having overheating problems?
Old Nov 9, 2011
Did you bleed it properly? Coolant coming from the overflow tank is a tell tale sign of a blown headgasket. Maybe you may want to pick one of these up,
http://www.amazon.com/UVIEW-560000-C.../dp/B000NPDL76
If you have a bad headgasket that will tell you. Otherwise I think you need to check to
a) See if your fans are coming on
b) Make sure you bled the system properly
Is your heat hot?
Old Nov 9, 2011
lame05's Avatar
Thanks ill have to pick that up and yes it was bled properly jacked up with heat turned on full blast, radiator cap one turn loose and ran for two complete fan cycles
alex_nyc
Jun 16, 2015 01:43 PM
zaboomafoozarg
May 30, 2015 09:21 AM
Allecr3
May 22, 2015 01:24 PM
F1wanabe
Apr 27, 2015 11:06 PM
Blaster30
Apr 22, 2015 12:21 PM
