Engine start problems Post issues with engine start here. Does not start, does not run, etc.
Civic 2001 D16v1 no start when cold
Old Jan 1, 2022
TonyScott's Avatar
TonyScott is an unknown quantity at this point
First of all i would like to say hi to everyone here!
i have a civic 01, d16v1 the problem is that it wont start when cold -1C is enough
it cranks but wont start
i did check fuel pressure ist 3BAR
i have spark on all 4 cylinders
replaced:
fuel pump
fuel rail and injectors
cam and crank sensors
air intake sensor
coolant temp sensor (top one)
spark plugs
coils
i cleaned grounds
cleaned EGR valve
checked voltage drops on alternater and on engine block is 0.32V in peak
i have tried with new battiery with starter nothing...
for sure its no timing belt as it drives and accelarates fine
oil is 10w40 but in a -2C i doubt thats even matter
car start just fine when its 0C outside and above ofc
i even took ECU at home to keep it warm
still no luck i am not able to start her. its going on for over two years and only in winter
few days ago after replacing injectors i have removed camshaft sensor and she started for a brief moment it was -8C and i was able to repeat that few times
it seems that when cold spark and fuel are just not in the good time...
when i crank few times sparks are all fuel wet. i even try to warm sparks with flamegun. no luck only trick is with cam sensor (not OE)
does one have any idea what i could check ?
Old Jan 1, 2022
FRSam's Avatar
Click Here
Re: Civic 2001 D16v1 no start when cold
Typically spark plugs will be coated in fuel because of leaky injectors. I would verify that they were properly installed.
Aftermarket sensors won't help, either.
Old Jan 1, 2022
Try OEM, honda finicky with aftermarket sensors
Old Feb 28, 2022
Albetx's Avatar
Albetx is an unknown quantity at this point
Did you find a solution?
Old Feb 28, 2022
Colin42's Avatar
Post your own thread describing your problem and what you have tried so far
Old Dec 3, 2022
TonyScott's Avatar
So far the only solution is to remove the coolant temp sensor plug, start the car, connect the plug back. I have switched the coolant sensor but no luck, still have to do that trick...
Old Dec 14, 2022
Albetx's Avatar
I have 99.9% the same symptoms, mine also starts after removing the coolant temp sensor.
I'm sure it is one of the sensors but still can't tell which one.
The service can't find the problem too because after the first start it starts with no problem.
Old Dec 14, 2022
Colin42's Avatar
Buy an oem sensor, the guy at the parts counter can help you
Old Dec 14, 2022
Albetx's Avatar
Already replaced the temp sensor (twice) with original Honda sensor, this it not the problem.
Right now I suspect the MAP sensor.
BOZOtc
Feb 14, 2017 11:19 PM
mkjohnson831
15
Nov 11, 2016 01:48 PM
Ken71701
30
Oct 28, 2016 08:20 AM
mindi.carr
27
Jan 14, 2014 09:31 PM
