Engine start problems Post issues with engine start here. Does not start, does not run, etc.
2003 Civic hybrid post repair issue [solved]
Old Mar 14, 2023
Coolergrain's Avatar
Coolergrain is an unknown quantity at this point
Hey! I have an issue that cropped up after changing the valve cover gasket and spark plugs on my 2003 Honda Civic and would much appreciate some advice.
Once we put everything back together and reattached the negative terminal on the battery, 3 lights began rapidly flickering on the dash. We took the terminal loose and then put it back on and the flickering did not return. I put the key in the ignition and attempted to start it. It did not start. Additionally, the light flickering returned and I could not turn the key back to neutral to remove it until we pulled the negative terminal again. We repeated the sequence a few more times, checked electoral connectors that we had disconnected to do the repair, always getting the same result.
Any help with this issue would be appreciated!
Old Mar 14, 2023
re: 2003 Civic hybrid post repair issue [solved]
connect an OBD reader and check what codes are stored.
Any car parts store can do it for free
woups, no start - see if any of your friends have an reader
Old Mar 14, 2023
Thank you. It'll give me an excuse to go get one. I've needed one for a long time. Do the very basic ones do the job?
Old Mar 14, 2023
Problem solved. The ground on the main engine block wasn't tightened down.
Old Mar 14, 2023
Re: 2003 Civic hybrid post repair issue [solved]
glad you found the issue.
for OBD readers, please make sure you get one that can read honda specific codes - not all readers can do that
you have an option to get one of those "dongles" that stick to the OBD and connects to your smart phone (that will allow you to monitor and record data, you can even reset codes while driving - if you have a phone holder, don't get too distracted while driving!!!). Use the app torque to connect - you can find them in Amazon. The WIFI ones screwed my phone WIFI, I prefer bluetooth
BAFX BT? Is what i chose
Old Mar 14, 2023
Colin42's Avatar
Bluedriver is a good Bluetooth one, it will do abs and airbags as well as engine codes
Templarjj75
Electrical
Dec 7, 2022 05:41 PM
Osd_cano
Jan 27, 2020 10:45 AM
hybridrob
Feb 5, 2018 01:39 PM
sayian
May 24, 2017 11:39 PM
mudhenFUF
Aug 21, 2013 09:37 AM
