Engine start problems Post issues with engine start here. Does not start, does not run, etc.
2002 Civic Si Fuel Cutoff/ Inertia Switch Location
Old Mar 14, 2023
rylanator25's Avatar
rylanator25 is an unknown quantity at this point
I’m the owner of a 2002 civic Si I was in a rear end crash and now the car will crank but not start. However it will start on starting fluid for a brief moment. Does anyone know of a possible fuel cutoff/inertia switch and (if a thing) a location?
Old Mar 14, 2023
Colin42's Avatar
Re: 2002 Civic Si Fuel Cutoff/ Inertia Switch Location
Never heard of that on civics. How badly were you rear ended? Maybe the fuel pump wiring got pinched
Old Mar 14, 2023
Originally Posted by Colin42
Never heard of that on civics. How badly were you rear ended? Maybe the fiel pump wiring got pinched
The car was going about 20-25 and hit me in the right rear and shattered my rear glass and everything.
Old Mar 14, 2023
Colin42's Avatar
So how much is the trunk pushed in?
Old Mar 14, 2023
it’s dented in pretty good the hatch will no longer open
Old Mar 15, 2023
BrotatoChip's Avatar
Super Moderator
Check engine light on? SRS light on? Do you hear the fuel pump priming when you turn the key on? Did any airbags or seat belt tensioners go off? I'm not aware of any inertia switch either. No mention of something like that in the service manual that I can find.
Dreamon
Exterior
Aug 20, 2019 09:56 PM
Chancé Doucet
General 7th Gen
Aug 8, 2015 04:54 PM
thelatinpimp
Jun 18, 2007 08:52 PM
vokals
Jul 15, 2002 03:36 PM
TonnyHegger
Apr 19, 2002 11:05 PM
