Engine start problems Post issues with engine start here. Does not start, does not run, etc.
P1361 no start
Old Mar 20, 2023
Sabin-_-P's Avatar
Sabin-_-P is an unknown quantity at this point
P1361 no start
So I've been plagued with the P1361 code for a while and have tried replacing the sensor to no avail. So today I decided to check my timing and I noticed it seemed a little loose so I ended up redoing it and getting it tensioned good. After I put everything back together I tried to start it up and it starts for a second but then dies right after, sometimes if I disconnect my TDC sensor it will run but in limp mode like usual and the second I plug the TDC in it dies. I've checked and double checked my timing and made sure everything is plugged in but I still have no clue whats wrong...
Old Mar 20, 2023
Colin42's Avatar
Re: P1361 no start
What brand of sensor did you use?
kevin2001
May 22, 2021 03:49 PM
brokercar
Sep 21, 2020 05:34 PM
Ken71701
30
Oct 28, 2016 08:20 AM
southerngirl.pt
May 17, 2014 09:01 PM
xRiCeBoYx
71
Apr 9, 2011 01:40 PM
