Engine start problems Post issues with engine start here. Does not start, does not run, etc.
No crank No start HELP
Old Jun 5, 2022
BigJoe74's Avatar
BigJoe74 is an unknown quantity at this point
I have a 2001 civic 2dr auto. Car died on me one day going to work. After asking some folks about my situation they suggested replacing the starter. I pulled the old one brought it to Oreilys and they put it on the tester and it was dead. Got the new one put it in. When I went to start it it sou ds like the starter motor is the only think making noise. Engine is not seized up but engine wo t crank over. All fuses are good and has fuel and spark.
Old Jun 5, 2022
FRSam's Avatar
Click Here
Re: No crank No start HELP
Use the crank pulley to turn the engine over. Remove all the spark plugs to eliminate any resistance.
Or post a video of what it sounds like.
Old Jun 5, 2022
have someone to look if the engine is turning over when cranking
Old Jun 9, 2022
BigJoe74's Avatar
the engine does not turn over when you crank it. I went and got a new starter and had the parts store bench test it in front of me to ensure it works as intended. There has got to be something preventing enough power to get to the starter so it can turn over the engine?
Old Jun 9, 2022
BigJoe74's Avatar
I tried to post a video of what it sounds like but the forum doesn't like the format my phone takes videos in lol. But to describe the sound, it just sounds like the starter motor is spinning and not engaging.
Old Jun 9, 2022
https://www.civicforums.com/forums/3...ust-spins.html
Old Jun 9, 2022
you need either a youtube or imgur site to post
Old Jun 9, 2022
FRSam's Avatar
Click Here
My guess is that it's actually cranking but there's no compression. Snapped timing belt?
Old Jun 11, 2022
BigJoe74's Avatar
no timing belt isn't snapped. When I have someone try and start the car and watch what happens i hear the starter motor spinning and I watch for the pulleys to spin when the motor would be spinning but nothing spins. Its almost like the starter motor isint engaging but it did on the bench test. Ive tried tapping with a hammer whils someone tries to start it thinking maybe its stuck but that didnt work either and its getting power.
Old Jun 11, 2022
Colin42's Avatar
Take the starter out and look at the flywheel
Old Jun 11, 2022
BigJoe74's Avatar
I have and the flywheel looks good. Nothing is chewed up and engine isn't seized up either.
Old Jun 11, 2022
Colin42's Avatar
Automatic and manual starters are different, are you sure you have the correct one?
Old Jun 11, 2022
BigJoe74's Avatar
I made sure I got the right one. It is a reman starter though. I've so seen where I can try to turn the flex plate slightly as the starter .ay not be lining with the flex plate
Old Jun 11, 2022
Colin42's Avatar
That shouldn't matter, that's why the teeth on the starter are bevelled. Reman just might be junk
Old Sep 21, 2024
03EXHonda's Avatar
03EXHonda is an unknown quantity at this point
Did you find the problem? Curious because I’m having the same issue now with my 03 EX
Lilslamdcivic
General 6th Gen
Apr 27, 2018 06:50 AM
Roadkillon93
Jul 25, 2017 12:59 AM
wpendl1
May 1, 2017 04:14 PM
Oleschool
Jan 30, 2017 09:07 PM
squirrelsurf69
Nov 16, 2012 09:14 PM
