Engine start problems Post issues with engine start here. Does not start, does not run, etc.
help p1519 won't start
Old Apr 1, 2006
03civ's Avatar
03civ is an unknown quantity at this point
I was hooking up some new speakers in the rear deck and while i had a lot of stuff taken apart i ran some heavy cable up to the engine compartment for a future amp. I poked it carefully through an existing rubber grommet I believe it's the main harness grommet. everything went pretty good and when i got everything back together now my car won't start. I got my code reader it gives me p1519, i've tried clearing the code, disconnecting the neg bat cable, checked for obviously disconnected plugins, fuses... nothing.
p1519 is idle air control valve circuit failure, what is the idle aircontrol valve?
oh, its a 03 civic lx
Old Apr 11, 2006
2k2civic's Avatar
the IAC very important if you want your car to start and idle like it should. You may have shorted a wire or something. What I would recommend doing is tracking down the wire at the ECU harness and testing it to be sure its not shorted. Someone who has a shop manual should be able to help you with specific instructions and testing procedures.
Old Apr 11, 2006
blouisgod's Avatar
Life Begins > 6800rpms
if its an 03, is it still under warranty by chance? like 2k2 said, it sounds like you shorted something by the code it threw, the relay may be gone on the IAC. the IAC is responisble for letting the air into the tract when starting the car among idle regulation, without it you get nothing.
Old Feb 21, 2023
AnthNirvanaA1G's Avatar
AnthNirvanaA1G is an unknown quantity at this point
Re: help p1519 won't start
I had this code and it went away after cleaning IACV. Did you replace it with a Denso?
Old Feb 22, 2023
BrotatoChip's Avatar
Super Moderator
This thread is 17 years old...
Old Feb 22, 2023
Replied to this one by accident lol
Supreme_One
Jul 12, 2023 07:36 PM
race_boy02
Mar 5, 2014 06:40 PM
atkinson40
Oct 19, 2013 07:53 PM
kooner69
Sep 24, 2007 10:23 PM
vargasr66
Jun 5, 2006 11:12 AM
