Idle Hunting - Code 7?
Old Oct 19, 2013
atkinson40's Avatar
LOCO!! And The Papers To Prove It
atkinson40 is an unknown quantity at this point
1990 Civic DX 1.5L
Symptoms: Idle hunts only after it warms up. Sometimes throws a code 7 and then it will stop hunting and idle OK.
Fix Attempts:
1. Replaced IACV - No Help.
2. TPS voltage all the way to the ECU. Varies between .6 to 4.1 VDC.
3. Bled coolant system - OK
4. Spraying carb cleaner around the tandem valve control diaphragm gives a change. I think this is what its called.
Any ideas? Can #4 leak and cause this problem? Thanks kevin
sharp66
31
Jun 12, 2022 08:45 AM
jbradley4809
Apr 7, 2017 04:23 AM
Vanman
Jun 9, 2015 08:17 PM
