Engine start problems Post issues with engine start here. Does not start, does not run, etc.
New starter bad?
Old Nov 11, 2022
daily_undriver's Avatar
daily_undriver is an unknown quantity at this point
New starter bad?
2005 Honda Civic, automatic, 4cyl (not hybrid)
I am at my wits end with this.
Car started gradually having trouble cranking, I'd have to turn the key a couple times.
Now it won't turn over at all.
Replaced Starter
12.6 V at battery and on Starter Solenoid
Buzzing noise in steering column when I try to crank the car
Tried starting in neutral and still nothing.
Should I yoink the starter out and go buy another one?
I'm about to have to call a mobile mechanic because it's near impossible to get towed from where I'm at and my car has to be gone by the end of today. Am considering setting it ablaze, lol.
I realize this is probably a basic *** question but all my searches pretty much point to me needing a mechanic to come out and find the ghost in the wires.
Thanks so much for your time
Old Nov 11, 2022
Colin42's Avatar
Re: New starter bad?
Buzzing in the dash/column usually indicates a bad ground. Triple check the battery and starter connections, make sure they're tight with clean shiny metal. Starter grounds through the trans. If you have the battery terminals that just clamp the bare end of a wire check for corrosion in the wire.
Xav
Sep 26, 2022 02:57 PM
jennkemp09
May 27, 2022 10:58 AM
jf42
Oct 23, 2020 09:04 PM
gabrown2
Apr 11, 2015 08:22 PM
2003civlxhockey
Florida
Jan 22, 2014 07:20 PM
