Engine start problems Post issues with engine start here. Does not start, does not run, etc.
Civic died and won't start
Old Dec 3, 2022
Joe Jr's Avatar
Joe Jr is an unknown quantity at this point
Hello all! New to the forum. I have a 2002 Honda Civic LX. It's only got around 150k on it. It's been running strong, no issues until it just died the other day. I was sitting at a stop light, took my foot of the brake and onto the gas, and it died. I've verified I've got spark on all 4 coils. Also verified the fuel pump is working fine. Hooked up the OBD and the only code I'm getting is for the catalytic but that could be the 02 sensor, shouldn't kill the car. Tried putting a little starter fluid in it to see if it would fire, and nothing. Am I missing something? Any help would be greatly appreciated. Thanks.
Old Dec 3, 2022
FRSam's Avatar
Click Here
Re: Civic died and won't start
Does it whir when turning over instead of the typical chugging sound? Have you done a compression test?
If the cat is plugged enough, it may be causing some problems, but at 150k, unless it's burning an astronomical amount of oil, it shouldn't be an issue.
Are you able to post a video of attempting to start it?
Old Dec 3, 2022
Joe Jr's Avatar
I haven't checked compression yet. Was thinking that might be my next step. Seems to sounds like a standard crank when trying to start it. I'll post a video when I'm back with the vehicle. It doesn't burn oil at all. No noticeable leaks, or oil smell. Never have to check and add oil between changes. Recently did an oil change and put all synthetic in.
Old Dec 3, 2022
remove pipes to check if cat is plugged or not
Old Dec 3, 2022
Joe Jr's Avatar
Yeah, was just thinking that as well. But, to my knowledge, on this vehicle the cat is in the exhaust manifold I believe.
Old Dec 3, 2022
ow, darn, yeah, saw that now, you have a LX...
Loosen the header from heads and see if it will start - if yes, it is plugged.
Remove the spark plugs first and let it dry in case you l=flooded trying to start it
Old Dec 3, 2022
Joe Jr's Avatar
Great advise. Thanks. Also wondering if it could be a cam position sensor? Maybe it's sparking in the wrong order? I don't know. It just seems weird that it would be running fine with zero sign of sputtering or loss of power, and then die completely. And after that, not attempt to fire at all. Just crank and crank without a sputter. I would think if it was the cat, or part of the fuel system, or the ignition coils, I would have "symptoms". Or at least an attempt to start.
Old Dec 3, 2022
FRSam's Avatar
Click Here
Cam sensor would throw a code. It would also still run.
Check timing and compression then go from there.
greasemonkey30
Sep 1, 2021 10:51 PM
mkjohnson831
22
Jun 12, 2016 07:46 AM
Gugle
Aug 29, 2011 04:23 PM
roushman
Jun 21, 2011 08:49 AM
