01 Lx Cranks But Wont Start
Old Aug 28, 2011
Gugle's Avatar
Gugle is an unknown quantity at this point
I've had issues on and off with this car since I got it 4 years ago, but with that being said I've put over 100,000 miles on it (currently around 205) on the odometer.
I think the problem started with a misfire in one of the cylinders (i dont have a scanner so now way to tell). For a couple days it would start up rough(belts squeal on start up, maybe a sign?), i'd give it a little gas and it would smooth out. But now it wont start at all. Sounds like it almost stalls out when I try to crank it over. I've read a lot of helpful suggestions and will try to gather more feedback, but out of desperation I ask if anyone has any suggestions throw em at me. I plan on removing the spark plugs as soon as my lady gets off work and returns with an extension for the socket. I've got a relatively new starter, battery, brand new alt. The battery has plenty of juice, I just can't get the sucker to turn over. I've had reoccuring internal headgasket leaks but my fluid loss was still minimal. Is there anyway to test a CKP without removing the timing cover? Thank you in advance for your time.
Old Aug 28, 2011
MindBomber's Avatar
Live for the Twisties
Re: 01 Lx Cranks But Wont Start
If it's the cps sensor you should have a code stored in the ecu, but it won't always throw a code. replacing it would probably be my first move, even though it's a major pain. Remember to use lock tight if you replace it.
Old Aug 29, 2011
Gugle's Avatar
Thanks for the advice. I actually got it started back up by replacing the number 1 spark plug. The tube seal has begun to leak and compromised the spark, but it's running at least lol. Thank you once again.
Old Aug 29, 2011
MindBomber's Avatar
Happy to hear it was such a simple fix!
Wild Cranker
427
Jan 28, 2016 06:49 PM
redej2
Apr 29, 2015 01:47 PM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
black2k1vtec
Dec 6, 2001 09:49 PM
