2005 honda civic cranks won't start
Re: 2005 honda civic cranks won't start
Fill the tank with fuel and prime the system by turning the ignition switch to II position (not engaging the starter) for at least 5 seconds. Do this a few times then try to start. Don't run the tank dry - could damage/burn out the fuel pump.
Check these fuses: #6 (15A) in the under-hood fuse/relay box and #17 (15A) in the under-dash fuse/relay box
Your fuel filter in the tank may also be clogged with debris from running dry too.
Did you actually run it completely dry and it sputtered and quit? The reason I ask is because I thought I had run out of gas. Starting it for the first time that day, it turned over fine but wouldn't start. There were no codes. I can fix most things on this car but I had to tow it in because I figured it was a computer thing. I cannot find the receipt/report of what they actually did, but I think they had to re-flash the ECM (engine control module). I have heard of the keys going bad because of the chip inside of it, but that wasn't my case. Anyway it has worked fine since then. I have a 2002 Civic si,
clc
41
Oct 19, 2017 02:27 PM
josephestrella8
Oct 25, 2016 12:22 AM
YodaGuy5
May 29, 2010 11:22 PM
