Engine start problems Post issues with engine start here. Does not start, does not run, etc.
03 civic no spark...
Old Dec 2, 2025
fivealive's Avatar
fivealive is an unknown quantity at this point
Hi everyone. Situation: 03 civic dx sedan, 223k miles, 1.7L D17a. I recently put the engine in (October 2025), hooked everything up, and tried to start it. No joy!!!
I can clearly hear the fuel pump power up. No engine lights (don't know if there should be any, after sitting for 4 years with no battery?!?!) I did replace one of the relays (brown, far right, behind glove box.) I checked all of the fuzes, and they are good (not burned out.) I also checked all of the coils; no spark. Any suggestions??? Thanks for all of your help in advance...
Old Dec 2, 2025
FRSam's Avatar
Click Here
Re: 03 civic no spark...
There's a lot of things it could be. The anti-theft system can cause it (there's a pretty good diagnostic pathway on here somewhere to verify its function), and I'm pretty sure no communication/a bad crank position sensor cuts spark (it's been a long time since I've had my '01 but I recall that being an issue for me), but it's more than likely a bad connection/ground somewhere.
If it's not those and you're able to confirm that the fuses and harnesses are good (beyond a visual check - use a multimeter), there might be an issue with the ECU itself. It's pretty common for failing when the alternator bolts aren't tightened fully.
Old Dec 2, 2025
fivealive's Avatar
Cool. Thanks FRSam!!!
Tony Matthews
May 18, 2023 01:02 PM
Iamjpg
Jan 29, 2022 02:06 PM
nathanp1592
Nov 9, 2010 07:49 PM
Metallica454
Aug 23, 2004 01:52 PM
JoeB16
Sep 24, 2002 01:32 AM
