Engine start problems Post issues with engine start here. Does not start, does not run, etc.
CRANKS but won't start!! Help
Old May 18, 2023
Tony Matthews's Avatar
Tony Matthews is an unknown quantity at this point
03 civic sedan lx 1.7l
Has power to the coil packs
spark plugs replaced
tested coil packs all are good
replaced fuel pump (needed it anyways
timing belt isnt broken either the lifters are moving
Just seems like it's not getting any spark whatsoever idk what to do anymore....im about to put a temp sensor and a fan switch in because someone told me that can keep it from starting and one of the sensors wasnt reading the multimeter test... any advice??!
Old May 18, 2023
BrotatoChip's Avatar
Super Moderator
Re: CRANKS but won't start!! Help
Troubleshoot before throwing parts at it.
Any fault codes? Green flashing key symbol in the cluster? Replacing the fuel pump doesn't confirm you have fuel. Timing belt still in one piece doesn't confirm engine timing either.
Old May 18, 2023
Colin42's Avatar
100% this, now you may have unintentionally put bad parts on
jearhart
Apr 15, 2018 10:56 AM
ChevyGuy3
Oct 17, 2014 01:06 PM
GolNat
22
May 3, 2014 06:59 PM
forevermemorabl
Sep 20, 2013 11:09 PM
95civic123
Nov 6, 2011 12:05 AM
