Engine start problems Post issues with engine start here. Does not start, does not run, etc.
Either starts perfectly or cranks only
Old Jun 14, 2019
Håkon's Avatar
Håkon is an unknown quantity at this point
Hi! I bought a 2003 Civic hatchback one week ago, but so far it has been nothing but trouble.
When test driving and buying the car it started fine everytime and the previous owner said that he had never had any problems with starting the car. After driving the car home, I let it stand for a couple of hours and when I went to drive it about 6 hours later, it didn't fire up. It cranks for days, but the engine just doesn't start. The morning after I went out to try and find out what was the problem, and it fired right up. No signs of any misfire or anything. I was a bit puzzled but reliefed, and went back inside to eat breakfast and pack. Tried starting it up again about two hours later and same problem. Fooled around with it for an hour before giving up and going back inside. After some time I decided to give it another try and once again, it started perfectly. I drove it to a workshop (was planning to have them change the timing belt and water pump anyways) and asked them to check what the problem could be. Of course it started up everytime they tried starting it over three days. Decided to take it back home rather than change out random parts in hope that it fixes anything. This morning I have the same problem. Started fine everytime yesterday, but today it only cranks.
The fuel pump hums when turning the key, the relay clicks, the timing belt has just been changed, so I really hope the timing isn't the problem. I don't have much tools or experience to work on cars, but I can get some. Do you have any ideas before I hand it over to another workshop? I am a student and would really like to not spend to much money...
Thanks.
(I'm from Norway, so please excuse any flaws in my english)
Old Jun 14, 2019
mac25's Avatar
Dr Krieger of Modification
Re: Either starts perfectly or cranks only
Could be the battery.
However, there is a known issue mostly with that generation regarding starting, that is most likely immobilizer based.
Try this. Before starting the engine just let the key sit in the position where all the dash lights are on; Wait 6 seconds and try to start it.
If the starting issue is resolved this way, then it's just something you're going to have to live with.
As of yet I haven't heard of the exact reason this happens, or the fix.
Old Jun 14, 2019
Slumpertcivic's Avatar
Highly suggest buying a obd reader that provides live data. The Bluetooth versions that sync to app on smartphone are usually quite affordable.
The next time it doesn’t fire up within 2 seconds of cranking, stop cranking and follow flooded engine procedure to see if it starts up after clearing out a possible flooded condition.
Being able to read what coolant temperature the ECU thinks and pressures can help narrow down if it’s a failing sensor issue.
Old Jun 17, 2019
Håkon's Avatar
Well. It's solved, and I feel like an idiot.
When I bought the car, I got two keys with it. I put one of them on my pretty heavy keychain, and left the other one "free". I bet you can guess what's the issue already. Well, the car starts fine with the "free" key, and only cranks with the other. I never thought about the fact that I was using different keys. Everytime I was going somewhere, I used my keychain, but when I was only trying to check the car, I picked the lighter one.
I am relieved, but feel very stupid for not realizing it earlier. The one that doesn't work doesn't even say Honda on it.
Thank you very much for your help!
Old Jun 17, 2019
Colin42's Avatar
that blank key may be able to be programmed to the car,
or if there's no chip in it it can be useful to take with you so you dont have to worry about getting wet and you can lock the real key somewhere safe in the car
Old Jun 17, 2019
Håkon's Avatar
That's a good idea!
I'll check if it's possible to program it. Otherwise I will take your advice on using it to unlock the car.
Twisties
Mar 7, 2019 10:27 AM
laxfan17
Jul 27, 2016 10:19 PM
5spdvroom
73
Jul 25, 2016 07:55 PM
rednek
Nov 3, 2010 11:38 AM
ironhide
Jan 8, 2010 03:49 PM
