Engine start problems Post issues with engine start here. Does not start, does not run, etc.
2001 Civic Start Problem Please Help
Old Jun 19, 2019
mrsplit's Avatar
mrsplit is an unknown quantity at this point
Question 2001 Civic Start Problem Please Help
Hi, I am brand new to this forum. I would love and appreciate any and all help with my NO START condition. My Civic has 235,000 miles on it. It would not start and the only code that I found with the loaner scanner that I used was a generic P0001 - Fuel Pump Regulator Open Circuit. I could hear the existing original fuel pump running. But, since the miles were pretty high and the fuel pump, filter and regulator are all part of the assembly/pump, I just replaced the whole fuel pump assembly (accessed it under the back seat). Unfortunately, I still have a no start condition. If I use starter fluid in the air intake, the car WILL start. I have checked every fuse under the dash on the driver side. I've also checked the fuel related fuse under the hood. I CAN hear the new replacement fuel pump running.
I don't know if it's possible that the PGM-FI relay separately sends a signal to the fuel pump and the regulator within the assembly. To me, since it will start with starter fluid, it would have to be a fuel problem. I'm getting spark or it wouldn't start. But, to be sure, I also checked the power side of the fuel injector plugs for power and they showed power. I purchased a fuel pressure test kit. But, I couldn't find any place to hook it up. Any help/ideas on what the problem is would be greatly appreciated!
Thank you,
Craig (alias-Mr Split)
Old Jun 21, 2019
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: 2001 Civic Start Problem Please Help
Cranks but does not start up? Try the other micro-chipped key? Bad main fuel relays behind the glove box?
P0001 is not a Honda code.
Old Jun 21, 2019
mrsplit's Avatar
Thanks for your help. I'll try those fixes.
Craig
Redhead818
Jul 1, 2018 04:15 PM
Jorge Alcoce
Aug 30, 2017 10:08 PM
tdbaker156
Oct 31, 2011 09:59 AM
aspencer80
Jul 28, 2009 12:41 PM
Mavrick272
Jul 8, 2009 12:09 AM
