Engine start problems Post issues with engine start here. Does not start, does not run, etc.
7th generation Honda Civic no start no crank - information
Old Jun 26, 2019
Brandonlee's Avatar
Brandonlee is an unknown quantity at this point
if your civic won’t crank or anything but has battery power check the ground on the start if the ground on the start is bad the car will only start by bypassing the ground until it’s fixes atleast I figured out that it was the issue in my car after replacing my starter with 178000 miles on it and going strong my car is a 2002 Honda Civic Ex with the 1.7 vtec motor and once you change the ground it should work like normal couldn’t find anything on this so I figured I would post about it in case someone else is having this issue
wpendl1
May 1, 2017 04:14 PM
jmcnroe
Jul 30, 2016 01:56 PM
mkjohnson831
22
Jun 12, 2016 07:46 AM
dxman10
Feb 28, 2011 11:02 PM
richs1000
Aug 15, 2010 12:14 PM
