Engine start problems Post issues with engine start here. Does not start, does not run, etc.
2002 civic 1.7L will not start unless given gas
Old Oct 21, 2018
ASchwagman's Avatar
ASchwagman is an unknown quantity at this point
I have a 2002 honda civic 1.7L 5 speed manual transmission. Just finished replacing head gasket and timing belt and now the car will not start unless you hold the throttle open and keep giving it gas. The head was resurfaced and its in time with new spark plugs. The car will idle really rough after a minute of giving it gas and seems like a misfire however no codes will be thrown. Im not a hinda expert so anything will help.
Old Oct 21, 2018
Wankenstein's Avatar
Re: 2002 civic 1.7L will not start unless given gas
May be related to a vacuum leak..perform a smoke test.
Confirm mechanical timing.
Failing/weak fuel pump?
Can you hear the injectors firing using a piece of pvc pipe or auto stethoscope?
Compression test
Old Oct 22, 2018
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
OEM NGK spark plugs only recommended.
Try the idle learn procedure. I assume battery was disconnected?
Check your timing again.
jward3535
Jan 8, 2018 09:12 AM
El Jefe
Sep 9, 2014 01:59 PM
yanksrule1121
Nov 16, 2012 08:48 AM
danielg
Sep 6, 2009 07:33 PM
Psythe
Jun 12, 2007 10:01 AM
