Civic Won't Run - Any Idea's?
Old Jun 12, 2007
Psythe's Avatar
Psythe is an unknown quantity at this point
I have a 1995 Civic CX and last week it just wouldn't start. The engine turns over perfectly but the car just won't fire.
It seems like I tried just about everything. The battery is good, alternator is good, got new spark plug wires, got new spark plugs, fuel pump is engauging, I am getting spark from the plugs. Theres lots of compression, I just had work done with the motor a month ago.
Also about 5 days before the car stopped starting up all together, the two middle cylinders weren't firing. Thats when I changed the spark plugs and wires but that didn't work. I was going to bring it to a mechanic but then it wouldn't start at all so I am kind of stuck now. Also another thing that seems odd is that when I pump the gas when trying to start the car, the two middle cylinders seem to flood a lot while not much gas gets on the numbers 1 and 2 cylinders.
If anyone has had similar trouble I knows of what I could try to get it working it would be greatly appreciated.
Old Jun 12, 2007
02civic21's Avatar
Ricky Bobby style, IWGF
02civic21 is a jewel in the rough02civic21 is a jewel in the rough02civic21 is a jewel in the rough
Re: Civic Won't Run - Any Idea's?
is it smoking? if the cylinders are getting flooded might be bad injectors or seals first thing i would do is a compression test or leakdown test
Old Jun 12, 2007
0H3ebpEM2's Avatar
0H3ebpEM2 will become famous soon enough0H3ebpEM2 will become famous soon enough
^^^ correct. Also check your timing if its running rough. It seems like your getting to much gas and its flooding the car.
Old Jun 12, 2007
Da1lyDr1ver's Avatar
try a new distributor.
vtec92
May 4, 2017 03:20 AM
usajags84
15
Aug 19, 2015 03:12 AM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
vtechcivic
Apr 21, 2015 06:58 PM
