HELP no spark 2002 civic
okay so my car was over heating due to a blown head gasket i got it replaced an had the head shaved down me an my dad put it back together an now it wont start it did before we did the gasket i made sure the timing was right we changed the crank an cam sensors thinking that would be it but the engine will turn but still no spark an it dosnt seem as if the fuel pump is pumping gas either someone helllp its been 3 weeks i havnt gotten to drive the damn thing haha thanks-matt
civic 2002 ex 1.7 automatic
Kenny the Ricer
Re: HELP no spark 2002 civic
Did you prime the fuel pump before attempting to start it?
It sounds to me you cranked it until it wouldn't crank no more, and that you've flooded the engine.
i took out a spark plug an touched it to metal when i turned the engine over no spark an put my ear to the gas cap to try an hear if it was sucking fuel an it didnt seem to be
Start by checking fuses, both under the dash and under the hood.
A quick way to check for spark is to leave the plug in the cylinder, take off the coil, and stick a test light in there see if it lights when you crank it over. (Ground it first)
Not really sure what you mean when you say you pulled the spark plug out, it was connected to the coil when you did this?
not really the best way to do things unless you secure a good ground wire from the spark plug to the engine block,
simply resting the spark plug against the engine will not work (well)
CarStuff
Dec 6, 2020 12:52 PM
smmahan
Apr 15, 2015 08:17 PM
CapYoda
Nov 11, 2001 05:17 PM
