Engine start problems Post issues with engine start here. Does not start, does not run, etc.
05 civic cranks but no start,tried everything I think
Old Sep 28, 2022
Mandy1969's Avatar
Mandy1969 is an unknown quantity at this point
It started running rough then shut off and won’t start, checking timing everything lines up, had all 4 plugs out and all firing, checked whole fuel system, had fuel rail off and all four injectors are spraying even spayed starter fluid in intake, new camshaft sensor, new fuel pump and injectors relay, checked all fuses, checked all ground cables. It just keeps cranking but won’t start!! Also green light for key immobilizer is doing what is supposed to do.
Is there anything else that it could be??
Old Sep 28, 2022
Re: 05 civic cranks but no start,tried everything I think
check alternator bolts? If they are loose, they tend to fry the ECU in these cars
Old Sep 28, 2022
Mandy1969's Avatar
U think ecu is fried?
Old Sep 28, 2022
check bolts first and go from there, that's just one of potential causes
facts first
Old Sep 29, 2022
BrotatoChip's Avatar
Super Moderator
Any fault codes? Check compression.
Old Oct 9, 2022
Mandy1969's Avatar
Checked alternator everything tight, no codes and there is compression in each cylinder
Randall Charles
Jun 9, 2019 02:44 PM
Dillano609
24
Oct 4, 2018 08:20 AM
Kerry Emerson
Jan 17, 2016 07:53 PM
jay.leija
17
Jan 16, 2014 05:34 PM
