Engine start problems Post issues with engine start here. Does not start, does not run, etc.
2001 civic doesnot start without the OBD device
Old May 1, 2019
hari2m's Avatar
hari2m is an unknown quantity at this point
Hi, I have a 2001 honda civic that recently got it to engine replaced. I haven't tried to start the car before the engine replacement. The car came with a blown head gasket. After engine replacement when I tried to start the car the car did not start and hesitated. Also, I observed the lights on the dash are dim. I connected a blue driver OBD code reader to read the codes and the lights seem to get back to its normal brightness. I was able to start the car as well. But I cannot start the car without the device connected to the OBD port. Seems like a grounding issue. but is there a way to determine where is the grounding issue. So far I cleaned up the ground connection at the battery negative terminal that connects to the chassis and transmission.
Old May 1, 2019
Re: 2001 civic doesnot start without the OBD device
Did you install the engine yourself?
Loose ground wires on the water neck
Handy pic
Old May 2, 2019
hari2m's Avatar
Handy pic
Yes, I installed my self. I found that the left ground wire from the image is disconnected. I cleaned it with a wire brush and connected it to the water neck and it worked.
Thanks for the help.
78sid
Electronics
15
Nov 9, 2021 09:21 AM
jdawgzcivic
Jul 20, 2020 10:57 PM
NeedHelp3
Apr 21, 2016 11:35 AM
Gordonbrowne
Jan 6, 2015 08:36 AM
