Electronics Post information/questions/Issues about Electronic parts here.
2006 Civic will only start with OBD connected
Old Aug 11, 2012
78sid's Avatar
78sid is an unknown quantity at this point
Engine would turn over but not start. There was a clicking noise coming from the inside relay/fuse area. Replaced the PGM-FI relay based on some other DIY threads. No change. Decided to see if we could pull a code with a borrowed scanner. When we plugged it up and tried to start after getting 0 codes, it fired and ran fine. When we unplug the scanner, it shuts down.???
I bought a scanner to at least save me the tow bill. I'm also going to check the main grounds.
Old Aug 11, 2012
78sid's Avatar
Re: 2006 Civic will only start with OBD connected
Higher end scanner pulled a PCM code
Old Dec 1, 2013
buwhoman's Avatar
buwhoman is an unknown quantity at this point
Did you find out what wrong?I have the same problem. Thanks
Old Sep 27, 2014
AndreyG's Avatar
AndreyG is an unknown quantity at this point
I had exactly the same symptoms with my sons old civic 2001 ex. I had similar problems after me and my son replaced head gasket and had to disconnect a lot of wires and reconnect them during reassembly. After reassembly car would turn but would not start. Accidentally I plugged in scanner in OBDII port to see if I can read codes, cranked the engine and it started. Without scanner connected to OBDII port it would die right away. While running I read code P0505 - fault of Idle Air Control Valve. Also car was running erratically during low RPM idling. But because Car would not start without scanner connected to the OBD2 port - it means that scanner through the port provides ground to PCM to start the car properly.
Answer is - while doing repair you have a ground wire undone somewhere and did not secure it well after reassembly. In my case wire I did not secure was under the air intake box - not visible after Air Intake is in place. During assembly I pried the ground wire the bolt slightly but forgot to tighten it with the wrench. I spent a half a day looking for the problem and researching it on internet, finally after tightening this G102 ground connection - all went smooth and car starts without a diagnostic computer connected to OBDII port. Hope it helps someone with similar problem.
Old Apr 5, 2017
struisman's Avatar
struisman is an unknown quantity at this point
This a great help. I have a 1996 Ford escort with the same hassle. Just had the head off (not me), and now the dash warning lughts are on dim with ign off, okay when ign on, but no starter etc, wont push start, brand new battery. I always thought it seemed like a bad earth, now I'll look more carefully. Thanks all
Old Sep 27, 2018
Trolleyman's Avatar
Trolleyman is an unknown quantity at this point
Having the same issues, replaced head gasket, timing belt/water pump, plugs. now car (2005 Civic LX 1.7L Non-Vtec) wont crank / start. Only when the scanner is plugged in? Going to check ground wire tonight. It is hard to get to, had a hard time removing it the first time. May have to drain oil and remove oil filter?
Old Sep 28, 2018
Trolleyman's Avatar
Red face Re: 2006 Civic will only start with OBD connected
Ok, what I thought was the ground turned out to be the knock sensor... Going to recheck the ground wires at the water thermostat housing.
Old Jul 2, 2019
Tracecross30's Avatar
Tracecross30 is an unknown quantity at this point
It seems as if this a common problem with these civic.
My 2002 civic ex,V-tec, have the same problem after I rebuilt the engine and replace the 4 bearings on the input shaft and secondary shaft Also . I finished put it back together on a Sunday afternoon and I drove it the Monday all day, the Tuesday after I got off work it starts and died about 40 seconds after I drove off. It start sometimes but it, shut off after and it will turn over but wont start.but if I connect the cable from the scanner to it it will start and run pretty fine ,even up until now that's what I'm driving with connected to my car.becaut I can't fine the problem.
Old Jul 2, 2019
Colin42's Avatar
you're missing a ground connection
Old Jul 2, 2019
Yeah, that's what I thought myself.
Old Jul 2, 2019
Colin42's Avatar
Start looking, lots of people forget the important computer ones near the water passage. Make sure the meter is clean and shiny
Old Jul 3, 2019
You talking the complete water housing that have the coolant hoses connected to it? If its that, I connect all the wires in that areas..I hope it's not the PCM Computer is bad even though I might have doubts that it is the computer, since so many people have the same issues and it turned out to be ground issues. I will check them today. Also, just yesterday I found out that I have no AC coming from the side vent in the car,only the ones where the radio at.
Old May 5, 2020
Derek Southers's Avatar
Derek Southers is an unknown quantity at this point
I’m have the same problem on a 01 Dodge Ram 1500. Did you figure it out? 😅
Old May 5, 2020
Colin42's Avatar
The problem is the big goat on the front
Jokes aside, the problem is usually that the engine is missing a ground connection. So make sure all the grounds are connected, and clean and tight
Old May 6, 2020
so the same thing happened to me last year. I bet it is the main ground wire just above the thermostat on the water support on the left side of the engine infront the radiator..or just check all the ground wires and make sure that the surface where they're grounded to are clean and check to see if anyone of them loose if anyone loose thats the reason for your problem. Good luck.
Old Nov 9, 2021
SuradMister's Avatar
SuradMister is an unknown quantity at this point
I strongly suggest checking your grounds as others have suggested. I had the same issue here:
Inconsistent Spark on All Cylinders after Engine Reassembly [solved] - Honda Civic Forum (civicforums.com)
When the OBD II reader is plugged in, one of the pins grounds the ECU/PCM. When you remove the code reader, it looses that ground and shuts down. This will leave some things working, like the starter, headlights, instrument lights, etc. The problem is that, without being properly grounded, the ECU cannot send spark to the cylinders consistently, if at all. This will fill up your cylinders with a bunch of gas, but the engine can't run without that gas being ignited.
You can check the strength of a ground as described in the video below:
Essentially, you're placing one probe of the multimeter on the negative battery terminal and the other on the ground you're trying to test. You should see very low resistance between the two probes on a good ground. Once you find a weak ground, I recommend cleaning up the areas where metal-to-metal contact occurs with electrical contact or parts cleaner. I used a brass or steel brush the clean corrosion and other grime off of the surfaces. The idea is to make it easier for the electrical contact to occur. Make sure any bolts or nuts holding the ground wire to the metal is tight enough to keep it securely connected so that the electrical connection will be strong.
It doesn't hurt to have your battery disconnected while working on this or on any electrical system.
hari2m
Engine start problems
May 2, 2019 10:20 PM
donna2838
Oct 10, 2014 01:17 PM
revr63ed7
Nov 2, 2012 01:12 AM
stacblssr
Aug 15, 2012 12:05 AM
Miz017
Jan 30, 2011 02:23 AM
