Engine start problems Post issues with engine start here. Does not start, does not run, etc.
Crank no start
Old Aug 10, 2021
Kelkel3513's Avatar
Kelkel3513 is an unknown quantity at this point
Crank no start
I have a 2001 Honda Civic EX 5 speed 1.7 307000 miles died on me driving down the road will crank but not start. Have changed fuel pump new spark plugs coil packs are good battery is good alternator is good starter is good not the immobilizer I'm at a loss at what else to try any ideas?
Old Aug 10, 2021
Colin42's Avatar
Re: Crank no start
Moved because not a DIY....
what does it do when you try to start it?
Have you verified if you're getting spark, fuel, compression, etc or did you just fire the parts cannon at it?
Old Aug 10, 2021
Re: Crank no start
check fuses under hood and dash?
any engine codes?
Old Aug 10, 2021
Kelkel3513's Avatar
Re: Crank no start
It turns just like its gonna crank doesn't lag or anything. All fuses are good it gets spark and no pressure issues with the fuel. No codes at all. Even tried starter fluid and it didn't crank then. No over heating or anything when it died. I've checked literally every fuse I can find I side and under hood. Could the ignition switch cause that?
Old Aug 10, 2021
Re: Crank no start
does the green key light keep flashing after you insert the key? it should go off after a second or so
Old Aug 11, 2021
Colin42's Avatar
Re: Crank no start
Check compression
Old Aug 11, 2021
Kelkel3513's Avatar
Re: Crank no start
The green key doesn't come on at all.
Old Aug 12, 2021
FRSam's Avatar
Click Here
Re: Crank no start
Sounds like an immobilizer issue.
Old Aug 12, 2021
Kelkel3513's Avatar
Re: Crank no start
I took off the immobilizer and the plastic piece between board and plastic is all broken I'm guessing that could affect it?
Old Aug 12, 2021
Colin42's Avatar
Re: Crank no start
Pictures?
Succubus062388
Dec 20, 2019 06:37 AM
jameschris777
Jun 8, 2019 07:02 PM
wpendl1
May 1, 2017 04:14 PM
growapair2
Feb 28, 2015 12:07 PM
roushman
Jun 21, 2011 08:49 AM
