Engine start problems Post issues with engine start here. Does not start, does not run, etc.
7th gen, whine no start
Old Jan 1, 2023
JR05civiclx's Avatar
JR05civiclx is an unknown quantity at this point
My 05 civic lx 1.7l A/T 170k miles turned off while entering freeway. After being towed home, next day car would not turn. Battery good had auto store test battery, starter and alternator needed to be rebuilt local shop.
Car whines but won't start. Does anyone have process of things I should check?
Old Jan 1, 2023
Colin42's Avatar
Re: 7th gen, whine no start
Sounds like the timing belt snapped
Old Jan 2, 2023
Thank for the quick response is it difficult to change?
Old Jan 3, 2023
Colin42's Avatar
No but there's a good chance a bunch of valves are bent
Old Jan 3, 2023
BrotatoChip's Avatar
Super Moderator
It cranks but won't start?
Old Jan 3, 2023
thetut's Avatar
thetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of light
To check for a broken timing belt:
Remove oil fill cap
Have someone try to start the car
Look into the oil fill hole
If you see rotational movement the belt is ok
If not then the belt is broken
Old Jan 3, 2023
if belt is broken, I would not try to crank further, it could damage more parts
TheWiz
Electrical
Apr 21, 2020 07:16 PM
Nettie
Sep 12, 2016 01:30 AM
dainfamouswun
18
Feb 7, 2016 03:34 PM
kbook
Apr 8, 2011 11:35 PM
