Engine start problems Post issues with engine start here. Does not start, does not run, etc.
car doesnt go, checked everything...
Old Apr 23, 2007
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
Unhappy car doesnt go, checked everything...
ok.. well as some of you guys know i blew my motor... i put my new one in, a complete d17a1 with tranny and vtec head. everything is in and works alright but it doesnt go anywhere. even when i put the car in gear in the air and try to spin the axles they dont go. basically i guess its down to the clutch but what could it be? i bled the clutch once already. when i first ran the car it moved for about 20 feet then the axles pop out and i got new axles. i thought that was the problem but now it still doesnt move. !!!
Old Apr 23, 2007
Re: car doesnt go, checked everything...
cmon help guys!
Old Apr 23, 2007
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
Sounds like somethings wrong with the transmission. Did you do all the regular checks like if you have enough transmission fluid? Maybe when your driveshafts popped out some liquid came out with it.
Old Apr 23, 2007
even if there was no tranny fluid. the tranny will still spin. but in any case i have filled it up with honda mtf. it spun before this point but then it stopped going after the axles popped out. i thought that was the prob but i guess not.
Old Apr 24, 2007
02civic21's Avatar
Ricky Bobby style, IWGF
02civic21 is a jewel in the rough02civic21 is a jewel in the rough02civic21 is a jewel in the rough
check the splines on ur axles and in the tranny if they popped out during an attempted acceleration then you might have stripped the splines in the tranny if not that then check the synchronizer in the tranny it is needed to make the gear stay in place so the car doesnt pop out of gear and you might have a bad one who swapped your engine id take it back and be like wtf
Old Apr 24, 2007
i swapped the engine. the axles are still in there good and how do i check the sychros? wtf? thanks for your help though. +1.
Old Apr 24, 2007
+1 to you too nameless! dont forget to rep back!
Old Apr 25, 2007
02civic21's Avatar
to check the synchronizer you have to pull the engine and get the tranny off the synchronizer is a unique looking gear in the tranny and if it is loose or has a broken tooth its bad but from what ur describing above it sounds like your synchro isnt engaging at all so it must be loose. when u put the tranny back to the engine did you align the clutch properly? did you check if everything was there and in its place it may have just been over looked (i dont play with trannys, too many moving parts, and little stuff) id take it to a transmission shop or get a salvage tranny this is not an easy thing and unless ur a tranny mech its gonna be frustrating
Old Apr 27, 2007
DaMadScientist's Avatar
Pwning Noobs 24/7
DaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really nice
new clutch ?
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
delacampos
Nov 7, 2001 09:18 PM
dubbc
Nov 7, 2001 02:24 PM
GoofyLogicInc
Oct 25, 2001 09:50 PM
