Engine start problems Post issues with engine start here. Does not start, does not run, etc.
2001 won't start in the cold
Old Jan 15, 2018
Treedguy's Avatar
Treedguy is an unknown quantity at this point
Well, I'm stumped.
2001 with 205k on it. Always super reliable in all kinds of weather.
Suddenly it refuses to start below freezing. It cranks fine but sounds "uneven" when cranking. It starts and runs fine above freezing. If it is close to 32 degrees I can floor the gas and get it running.
It threw a p0113 once so I checked the iat sensor. 5 volts at the connection. Replaced the intake sensor with a known good one.
Anyone run into this problem?
Old Jan 16, 2018
Colin42's Avatar
Re: 2001 won't start in the cold
have you tried putting gas line antifreeze in it?
Old Jan 16, 2018
Treedguy's Avatar
Yeah, that was one of the first moves.I tried the hair dryer blowing on the ECU yesterday. No dice. 11 degrees.
Old Jan 16, 2018
Colin42's Avatar
Hmm, that's not even that cold for up where I am. (My girlfriend's car was having a hell of time starting below -13F, put gas line antifreeze in every time she fills up and no problems now)
So when it's cranking it tries to start, a couple of the cylinders kind of "pop"?
IAC sticking? give it a couple light smacks with a chunk of wood
Verified all the cylinder have good spark?
All the injectors pulsing?
Have you tried ether?
Old Jan 16, 2018
Cranks uneven'?
Does it wet the plugs at that time?
How about ECT accuracy check on a scanner data list?
I might wonder about a compression test on a effin cold engine, and maybe a valve lash check/adjust
Old Jan 16, 2018
Treedguy's Avatar
I have 4 good sparks.It's not getting fuel.Now just today since it was near 32 I went to give it a try. It would not start unless I floored the gas pedal. It fired up ran smooth. Drove it around.Then.....CEL pops up.P0113I have swapped the IAT sensor with a known good one. (I have two civics) I also bought a new one. I back probed at the connector and got 4.99 volts.Bizarre.
Old Jan 16, 2018
IAT is a TWO wire sensor. What do you measure on the second wire? (it should be a ground)
Did you mangle the terminals trying to test it, now it has a poor connection?
Got a scanner that shows a data list? What does your IAT and ECT show in the data list?
Old Jan 16, 2018
Treedguy's Avatar
Voltage between the two wires is 4.99.Measured with the plug disconnected and also connected.Negative on the mangling.I am scanning with a simple OBD2 so only codes.
Old Jan 16, 2018
Treedguy's Avatar
Pulling the plug while the key is on will throw the CEL.
Old Jan 16, 2018
Ok then that sounds like wiring for IAT is ok at the moment you checked it----but it still sets fault code for a reason.
a scanner that can show live data might reveal much useful information.
A scanner that can record data for playback later is sometimes even better for intermittent failures.
If you have a scanner that displays live data, it would probably also display freeze frame data so we can find out what the IAT sensor read when it set the fault code.
If it read -40* at the time of failure, it was open circuit and you can chase the problem one way....but if it read +256* at the time of failure, then you need to go a different direction with diagnosis.
A sensor that is open or short circuit, or beyond its expected operating range can cause a fault code, as you probably know.
A skewed or bad sensor can read very wrong and can cause major upset--- but as long as it is within plausible range it won't necessarily code. The best way to find this sort of problem IMO is use a good scanner (or app) to see what the PCM sees.
IAT is a minor input (has minimal influence) for determining fuel injection calculations, but
ECT is a major input--so if it is skewed it can cause major fuel errors.
If ECT flakes out and falsely reports the temp is -38* when it's really +30*, the computer is gonna try to make the injectors squirt far too much gasoline and flood the engine....and you kicking the gas pedal to the floor might put it in clear flood mode and get it started.
Same skew deal goes for TPS, if its voltage goes high enough it might stop fuel injection during cranking without setting any code.
Old Jan 16, 2018
Treedguy's Avatar
Thanks for your reply. I appreciate it.I'll have to get the old girl down to the shop for a better scan.
Old Jan 16, 2018
I was just coming up with examples....
You can score some scanner units for fairly reasonable prices at the parts store, walmart, sears, etc.
You can pick up a bluetooth dongle and phone app very cheap too (google 'torque app') several people on the forum use this
Old Jan 16, 2018
Treedguy's Avatar
Excellent.I'll return with some answers.
Old Jan 26, 2023
Cobra1's Avatar
Cobra1 is an unknown quantity at this point
Originally Posted by Treedguy
Well, I'm stumped.
I've experienced the same problem for 3 years until I got lucky. I had a dummy key made first at Dealership. The ignition immobilizer was keeping the engine from starting. Had a new key that has a chip cut. Problem solved.
thedude
Oct 11, 2022 09:37 AM
Asblasor
Jan 12, 2018 12:18 PM
Thaik
Jan 21, 2013 11:48 PM
Asblasor
Aug 23, 2012 03:40 PM
player
Ottawa
Dec 23, 2005 10:42 PM
